One of the neatest little stoves
wg_bent
2,248
Poughkeepsie, NY
Today I was over at the local stove shop getting a chimney brush (that's for another post!)
and saw the coolest little stove I've ever seen.
(broken link removed)
The stove retailed for around 1300 bucks. The firebox is VERY small. I'd say it' could handle 1 good size split at a time, but given the design, I'd bet that stove gets every BTU there is out of that wood.
Hmmm that web site says its approved for only DIN and germany. whats DIN? Very cool looking stove!
Deutsches Institut für Normung (DIN) is the German version of our Underwriter's Laboratories (UL)
To install ze stove you vil show us your papers!
That is a cool stove. What is the contraption on the top? Looks like smoke would pour out of it, unless those are some sort of chamber.
BB, you kill me! Thanks! I needed a laugh!
Mike
gee; coal burning in that white room, silly germans.
Warren --- ASHLEIGH'S!!!
Yup, guess you saw that stove too. What surprised me was that it is rated a higher BTU output than the 1410.
The only site I could find it on was the Morso generic "all other country" site, yet there it was in the showroom.
It was clearly a wood burner though, not a coal burner. The firebox bottom was solid firebrick, not a grate system like the 1410 has that would allow coal.
The thing on top is a heat exchanger. The secondary burn tubes were in the lower section.
The Morso 1BO and 2BO were available back in the 1970s, which shows you how far ahead some of these European makers were. The top is additional heat exchanger and radiant surface.
The same stove was available smaller #2BO or #2B (without the heat exchanger). In fact, I once used a 2B in my sunroom at home. Really nice stoves...mine was in glossy brown enamel.
How long a burn time did you get out of it Craig? That is a seriously small fire box. Must be something like 8x10x16.
(broken link removed to http://www.morsoe.com/global/2BUO.htm)
What was it about the design that made you conclude that this stove was so efficient??
That heat exchanger design. You'd have to see how it all fits together. Granted it's my guess only, but the exhaust gass has to take a pretty long path before leaving the stove and there's a lot of cast iron in that stove on the way.
It's cute, but it would be a pain in the arse to clean...
Nice, but too small of a firebox. That heat exchanger reminds me of the old Montgomery Wards barrel stove I had in a house I rented years back. It had a big donut shaped heat exchanger on top. It use to fill up with fly ash in a couple months and was a pain to clean out.
I don't know why Morso's USA website is so far behind. There are several stoves available now that aren't on the site. Anyway, yes, you can see these at Ashleighs or at my shop in Shokan. They are a throwback to the 70's but updated with clean burning technology.
Warren, one thing I will mention about all these smaller fireboxes: Split your wood smaller. Do not try to use big logs. Smaller splits packed in tightly will be the best. Get a good coal bed first. Many of Morso's stoves are smaller fireboxes than we are used to. But they are very efficient. Just need to use the axe a little more.
Sean
