Hello All,
New to the forum but have lurked around here in the past for the great content and information from you all.
I am having a ton of creosote build up in my new chimney liner and was looking for some help/insight...
I have a 1970's era Timerline single door monster stove that was running and 8 inch pipe into my center of the house 11x7 flue brick Chimney. Never had creosote buildup. Always burned dry wood, mostly oak and ash. I was able to damp down and control airflow to have a nice slow, long burn. I need a slow burn because the stove is located in the center of the house on first floor. Burn temps are around 300 - 500. Any hotter I'd have to open windows.. lol
I was inspecting the chimney two years ago and noticed a few cracked tiles in the flue about 3 or 4 down that are within the house. Had a chimney guy come and say a liner would be best rather than tearing apart the house to re-build the chimney. He dropped down a 6 inch un-insulated liner and tied it into the 8 inch pipe with a reducer.
Since then I have had excessive creosote build up in liner, and in the 8 inch pipe going from stove into the liner. I've have been running it with less wood and leaving damper and air open to keep more draft going, but feel i am will be feeding it constantly.
I am leaning toward replacing the older stove with a more efficient one with a 6 inch pipe, but wanted any opinions prior to just ripping and replacing.
Would adding insulation around the 6 inch pipe in chimney help?
Thanks B
Thanks B
