Hey everybody,
I'm new to wood stoves and this is my first post. I wanted to run some things by the folks here to see if this project of mine was a going to work out. I've been researching like crazy, which I always do on my homestead projects, but wanted advice because there's more danger involved with wood stoves than the usual stuff I do.
I have an antique pot belly stove ( W.H Landers Co. Hustler #12 from Syracuse, NY). My buddy found it for free on the side of the road. Other than being rusty (which I'm taking care of), it's solid. There aren't any cracks or thin spots. I want to install it in my 14' x 10' cabin. The cabin isn't insulated or air sealed at all. I'll mainly be using the stove to warm up a bit on days in the early spring and late fall when I'm working on the land. Thus, I'm not concerned with fuel and usage efficiency, like if it were a houses main heat source. My avatar picture is of my cabin.
I've read through a whole lot of posts on this forum, the NFPA 211 and info on woodheat.org, and feel confident I can install it safely. It will take up a lot of space and use a lot of sheet metal for the wall protection but I think I can live with that.
So my questions are:
Even with small fires and considering the cabin is not insulated or sealed, does the stove still seem too big? I know there are small stoves on the market now for tiny homes and the like but they are way out of my budget for the time being.
Is it even a wood stove? If it's a coal stove could I use it with wood?
Does anyone have any Ideas what the hole in the bottom of the side is for? It opens into the ash clean out chamber. It's the only thing about the stove itself I'm not sure of. It's simply a hole, about the size of my thumb, with no signs of other missing parts. You can see it in the second picture.
Lastly, when measuring for clearances, should I measure from the widest point of the stove's belly or the part the stove pipe attaches to? You can see in the first picture how far it sticks out on the back.
The pictures are not my stove but I'm almost positive it's the same one.
I'll want to run the rest of my design past y'all but for now I'm just trying to see if this is even a good idea.
Thanks for giving this wood heat beginner your time,
Dave
![[Hearth.com] Old Potbelly in a Small Space Help [Hearth.com] Old Potbelly in a Small Space Help](https://www.hearth.com/talk/data/attachments/215/215268-d52024bba71193a3b4d4a8ab92462b14.jpg?hash=r4dj3_rPx1)
Dave
![[Hearth.com] Old Potbelly in a Small Space Help [Hearth.com] Old Potbelly in a Small Space Help](https://www.hearth.com/talk/data/attachments/215/215266-460c5ac286ea6737bbc61bdfd9fd2bff.jpg?hash=GbCdClRlju)
![[Hearth.com] Old Potbelly in a Small Space Help [Hearth.com] Old Potbelly in a Small Space Help](https://www.hearth.com/talk/data/attachments/215/215267-fa13d8a5c53ed88874ffa6f8d0b8ace7.jpg?hash=KNsUUxN0Je)
