Then it may need to come down. But you don't do that simply by pulling it down. You disassemble it from the top downupdated what i found behind the brick inside. i fear it has to come down now though.
Thank you, Yeah i figured as much. i did install a wood burning stove in our last home, but i had a attic to transfer from double wall to triple with the register box . not sure how i go about it with a ceiling that the roof is literally right above. The corner of the room would be ideal but the pitch of the roof maybe too much, it is approx 6ft pitch and i believe i have to go several feet above the ridge line. :/Then it may need to come down. But you don't do that simply by pulling it down. You disassemble it from the top down
It isn't hard to do with a cathedral ceiling at all. Just use a cathedral ceiling support box. And the chimney needs to be 2 feet higher than anything within 10 feetThank you, Yeah i figured as much. i did install a wood burning stove in our last home, but i had a attic to transfer from double wall to triple with the register box . not sure how i go about it with a ceiling that the roof is literally right above. The corner of the room would be ideal but the pitch of the roof maybe too much, it is approx 6ft pitch and i believe i have to go several feet above the ridge line. :/
The home inspectors absolutely cannot be help liable. All of their contracts cover themselves many times over. And there have been many court cases supporting thatEven with that language, if they missed something that most home inspectors would have discovered, it could rise to the level of Professional Malpractice. You based your purchase of this house on their report, if they missed stuff that they should not have you might have a case.
Thank you again, am i right in thinking it has to be above the ridge by a certain height also?It isn't hard to do with a cathedral ceiling at all. Just use a cathedral ceiling support box. And the chimney needs to be 2 feet higher than anything within 10 feet
It has to be 2' above anything within 10'. If the ridge is further than 10' noThank you again, am i right in thinking it has to be above the ridge by a certain height also?
Thank you, i guess a solid plan for now is make the outside of the chimney in those areas as water tight as possible, repair the damage then take down the chimney in the summer, then install a new one where we want come the fall.It has to be 2' above anything within 10'. If the ridge is further than 10' no
I want to say i had 6 ft of triple wall chromed chimney above the roof in our last place, ( although we are in Alabama we like a fire on a cold day. ) and we never had any draw issues that i am aware of.That being said most stoves need atleast 12' of chimney. Some need 15' to work properly
Don't wait until fall. Stoves and materials can become very hard to get a hold of in the fall. And you should have wood cut split and covered alreadyThank you, i guess a solid plan for now is make the outside of the chimney in those areas as water tight as possible, repair the damage then take down the chimney in the summer, then install a new one where we want come the fall.
Ok first off don't get triple wall. It is a far inferior product to insulated double wall chimney. And 6' above the roof may very well have been 12' overall above the stove.I want to say i had 6 ft of triple wall chromed chimney above the roof in our last place, ( although we are in Alabama we like a fire on a cold day. ) and we never had any draw issues that i am aware of.
Sorry i meant when it went into the attic i had triple wall, then outside again triple wall. i do not recall the reason i was advised that though. positive it was this (broken link removed)Ok first off don't get triple wall. It is a far inferior product to insulated double wall chimney. And 6' above the roof may very well have been 12' overall above the stove.
Yes don't get that. Spend a little more and get the better double wall chimney pipeSorry i meant when it went into the attic i had triple wall, then outside again triple wall. i do not recall the reason i was advised that though. positive it was this (broken link removed)
the length of the chimney would be around 14-16 ft id imagine if we put it where wed like.
sadly due to the ongoing other issues our money is draining quickly, i am pretty sure we can not afford to do this completely new for a few months at least.
Sorry if i am being annoying, ( im mentally fried is my excuse ) you mean like this? and it is sufficient even outside the home?Yes don't get that. Spend a little more and get the better double wall chimney pipe
No that is connector pipe and can't pass through ceilings or walls.Sorry if i am being annoying, ( im mentally fried is my excuse ) you mean like this? and it is sufficient even outside the home?
6" DVL 40" - 68" Double-Wall Telescoping Black Stove Pipe - 6DVL-68TA
6" DVL 40" - 68" Telescoping Pipe - Find 6 inch DVL black double wall stove pipe lengths here along with expert advice and installation information - NorthlineExpress.comwww.northlineexpress.com
clearly im being dense, i thought that is what that was, or thisYou want insulated double wall chimney pipe.
That is double wall insulated chimneyclearly im being dense, i thought that is what that was, or this
1![]()
6" x 48" DuraTech Stainless Steel Chimney Pipe - 6DT-48SS
6" x 48" DuraTech SS Pipe- Best selection of 6 inch Duravent double wall chimney pipe lengths.Expert chimney pipe installation tips. - NorthlineExpress.comwww.northlineexpress.com
i will do some forum searching so i do not annoy you, thank you again![]()
great , i got there finally, i will be back to bug you when it comes time to buildThat is double wall insulated chimney
It makes sense as much as i dont want or need the extra work. i am about to head out to get some adhesive flashing to try stop the water ingress for now while i take up the floor and see what beams need replacing. i have to go back to digging a new water main next week so this will have to wait until nearer the summer for the tear down. thankfully there appear to be 4 lengths of wood siding in the barn, so thats one less expense.At this point i think you're at tear it out and replace. I understand you dont have the funds to do this now but start planning for it over the summer and have a good game plan, and possibly materials, all lined up for the fall. It'll take a little bit of hard work to take that existing chimney down to the ground. Then you can repair the structure based on what you've found so far, and what you will find once it's outta there, and you will find more surprises. If you're really on a tight budget and want a wood stove in that room you can just reframe the structure once that brick chimney is out of there then install a Class A chimney system(i like Selkirk), you can install it without a chase, for $1500-2000. Learn the local codes for flues and follow them. Welcome to the joys of homeownership. I think most home inspections arent worth the paper they're written on but if you dont know houses and systems, what else can you do i guess. Even the best inspectors arent, cant disassemble a house just to make sure everything's perfect. Every house has issues, even brand new ones. I've seen 10 year old houses having the entire front of the house re-sheathed due to poor flashing around windows/doors so it does happen.
Inspectors are not permitted nor expected to start ripping out sheetrock, cement/brick etc to determine the construction of something. If they missed rotted subfloor that was visible under, or joists/beams - then yes you could chase after them but ultimately what you might get back is an insurance adjustment to help fund the repairs, for that particular issue, and nothing else that might be hiden.If the Inspector missed glaring defects you might have a case against them. I would check the inspection contract to see what it says. A call to a lawyer might be appropriate. At a minimum a bad Review about the missed Major Defect should be posted online.
