There is nothing on the sides just a rectangle tube on the back where the blower fan hooks upThe 24-AC did. Do you have a picture of the right side of the stove? There should be a bypass control there if it has a cat.
Thank you didnt want to hook it up and run it without if it was supposed to have itIt should be a non cat then
Ok thenIt's going into a brand new triple wall installed it last year and didnt like the woodstove I had so I sold it and this one was given to me
Should be good to go!! I own a sawmill and burn all my hardwood slabs so my wood is good and dryOk then
Good you will need allot of wood to feed that old beastShould be good to go!! I own a sawmill and burn all my hardwood slabs so my wood is good and dry
Lol thankfully it's not my primary heat sourceGood you will need allot of wood to feed that old beast
I'll have a look at the one I have; It's under one of my SIL's house in a semi-crawl space..more of a "stoop space." It doesn't have the tubes though. We might be able to guess how old it is from a serial # comparison. Looks very similar to what I have though..sweet little cigar-burner.@Woody Stover early 24a model?
Nice. You have to burn hot to burn clean in the old stoves, and the more heat you can rip off the box before it goes up the flue, the better. You might also try some kind of small 8" desk fan to pull more heat off theThere is nothing on the sides just a rectangle tube on the back where the blower fan hooks up
Might be a little more efficient than it would appear at first glance. Mine has a baffle welded to the back wall, at an upward 45* angle to direct the smoke forward again in the box, under the step-top and back into the hot front part of the fire. An early attempt at a cleaner burn.Good you will need allot of wood to feed that old beast
Generally baffles aren't about cleaner burns just a longer smoke path to extract more heat. Without extra air being introduced there no secondary combustion will happen. There were pretty early secondary combustion systems available but they all introduced air at that point. My old Cawley lemay was a pretty effective early secondary burner.I'll have a look at the one I have; It's under one of my SIL's house in a semi-crawl space..more of a "stoop space." It doesn't have the tubes though. We might be able to guess how old it is from a serial # comparison. Looks very similar to what I have though..sweet little cigar-burner.
I'll see if my pics have survived multiple hard drive crashes, with no backup.![]()
I seem to remember something in the literature, touting a cleaner burn, but I don't have the manual any more, and I didn't find the receipt yet, either..Generally baffles aren't about cleaner burns just a longer smoke path to extract more heat
Literature says lots of things. That doesn't mean they aren't making most of it upI seem to remember something in the literature, touting a cleaner burn, but I don't have the manual any more, and I didn't find the receipt yet, either..
True. You don't have to go much further than the BK thread on here to see a lot of that type of "literature."Literature says lots of things. That doesn't mean they aren't making most of it up
What stove did you have before..what didn't you like about it? I can tell you, this design will toss some heat, although my wood wasn't always the driest back then. And it's built like a tank.didnt like the woodstove I had so I sold it and this one was given to me....There is nothing on the sides just a rectangle tube on the back where the blower fan hooks up....burn all my hardwood slabs so my wood is good and dry
Right. My BIL's VC Resolute III has another air inlet below the main air control, and secondary air is introduced through a channel with holes in it, located in the bottom/rear of the box. When the bypass is closed it routes the smoke along the base of the fire to a low flue outlet, and with that oxygen is supposed to burn some of the smoke. When I look at the stack, it still looks like a smoke dragon though.Generally baffles aren't about cleaner burns just a longer smoke path to extract more heat. Without extra air being introduced there no secondary combustion will happen. There were pretty early secondary combustion systems available but they all introduced air at that point.
