Oh that's what that top pic was about..went over my head..lol.I've never seen that much buildup in anything I've burned. Scary to say the least. If you need an inspection door in your stove pipe, you have some mighty poor burning habits.
Maybe you should look at the new, smaller BKs.
Your dealer may be right in telling you that you will cook yourself out,(as I found even with the princess) but he is assuming you will be running it hot enough to ignite the cat, in your small home that might cook you out, but you can pull the cat out and then burn even lower and not cook yourself out, you will want to pull the cat if you burn at really low temps as the cat can plug up if left in, and used continuiously at very low settings, Just what works for me with a small super insulated home.
Once you go blaze king you dont mess with anything else. whatever one you use will leave you happy.
Isn't that an oxymoron, or something.Maybe I shouldn't call it propaganda. Everything in the sales brochure is fact
Not picking on BK.
most of it condenses right on the (cooler) insides of the stove , heavy thick black tar that just nicely burns away when I next have a hot fire
I have never seen anybody cover their windows like that..guess I don't get out much.
Anyways to the OP.
The King should be fine but have you looked at the Woodstock Progress Hybrid yet?
