md2002
Oh we understand. One advantage of a stand alone stove instead of an insert is the ash pan size.
You don't have to tell me my friend, I'm the one that needs to clean out the ash pan every 2 nights
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Maybe 9 tons of DF = 10 tons of Green Supreme? I need pellets and only live a couple miles from ECL but I seldom buy from them. I bought some Okie gold and Okie platinum from them last year to test. They were OK but too expensive for what you got. If I could get Fallon's to answer the phone I may be getting a ton or two this weekend.
So no way is 3tons of DF's equal to 4 tons of NEWP? I thought it sounded too good to be true... That's why I asked....Me neither!
I think someone's gonna be short on fuel come spring!
I have been a burner of the Oakies for the last 4 or 5 years. Last year at the end of the season I picker up 10 bags of the Douglas fir to try out. I didn't see a big difference in the heat output or much change In the ash content .Certainly not a buck twenty a bag more. I would call what the salesman at ECL said as B.S.
Now that said Home and Hearth (Fallons) Is out of Vermont's and doesn't see a delivery In the near future of them. SO With ECL out Fallons out and Pellets Direct out of the good stuff If It were me as a hedge against not finding any I would pick up the Douglas Fir Bite the bullet on the price and see what happens with the pellet inventory going forward into the burning season. I don't have a warm and fuzzy feeling this year about seeing excess inventory. Way to early to be seeing suppliers running out.
Jim
Same here. For me they are somewhat of a novelty, and definitely outside my comfort level as far as cost. It was a tough decision, but I do have a ton in the bunker for use exclusively during single digit / sub-zero temp weather. To offset the price, I also stocked up on a variety of different less costly brands as well. That helps to lower the average "per-bag" price into a more comfortable range, and allows me to sample different kinds of pellets so I know if they are worth buying again in the future.I put one ton of OK DF's into the 5 ton mix this year for use when it's single digit weather, although I've yet to max out the settings on the P-68 no matter what the weather. More curiosity that anything, I guess.
Hello jtakeman, I thought that DF "BS" would bring you out. Its fall an the stories start.Me neither!
....Now that said Home and Hearth (Fallons) Is out of Vermont's and doesn't see a delivery In the near future of them.
SO With ECL out Fallons out and Pellets Direct out of the good stuff ....
Jim
The DFs are the hottest I've ever burned. Will 3 tons last as long as 4 tons of another pellet? That remains to be seen, and I agree with the others it seems unlikely. I think what would tend to happen (at least in my case) is 3 tons DFs would last the same amount of time as 3 tons of any pellets. I tend to keep my stove at the same settings no matter what I'm burning. If I'm using NEWPs let's say, I'm getting XYZ heat value from them. If I'm using the DFs, I'm getting a lot more heat at the same feed / burn rate. So with DFs, the house is more comfortable in general, and the stove doesn't have to work as hard to get out of it's own way, but I'm also not burning less pellets. This is most relevant on the coldest days of the year when the stove really has to work hard to keep the house up to temp. $375/ton? No. Given the available choices, I would wait for the Golds to come back in stock, or see if you can find some La Cretes or North Country - those generally go for ~$300/ton as well and are excellent choices. You can get 5 tons of those for the same price as 4 tons of the DFs. If none of those are options, you could try your local Lowes, TSC, or HD and pick up what they have to offer for ~$240/ton this year. Worst case scenario you'd be getting Green Supremes which are the same as NEWPs anyway.
Mine look the same way. I've found that pretty much any pellets that come in bag with clear bottom look like they have lots of fines when viewing the bottom in the bag. Don't worry about that. See what things look like when you load them in the hopper.I just got my North Country in. I took a peak at the first few bags, and they seem to be loaded with fines on the bottom. any similar experiences with this type of problem? I've heard they are a fantastic pellet
Yes true. I have DF's for mid season burn when I will use two bags per day or even more on some really cold nights. When I hit 3 bags I mix them with a bag of what ever else I have on hand and that still cuts ash by quite a lot. Although here and as I recall last year the bags read 9200 BTU and some box store pellets are only 7800 ( Green Supreme I'm pretty sure is only 7800 actually). And the dealer this year has DF listed as 9200 again FWIW. . But anyway, I use them for the lack of ash as well in the mid season burn. I probably will use Energex again this year, the hards are advertised as 8700 BTU, definitely more ash than DF. I was hoping for Spruce Pointe but not at 7..49 a bag for 8700 BTU when Energex Hards are $5.85 when you buy a ton and also advertised as 8700 btu. I'm picking up a ton of those this week. I might run LG's for my shoulder season pellets, easy lighting pellets. They burn faster than LaCrete or Spruce Pointe but that won't matter much in the shoulder season ( also $5,85 a bag by the ton). I have some Energex Premiums now rated at 8600.Based upon the reports I've read the BTUs in a bag of DF pellets is at most 10% more than in your avg big box store brand. Something like 8800 BTUs for Okies vs 8000 for your average stuff. There's no way that 3 tons of DF can equal 4 tons of the regular stuff. When you do the math, you'll find that the BTU/$ of the expensive stuff isn't a good value. However, I love DF pellets and if I could afford them, I'd buy them not for the heat, but for the cleanliness. They leave so little ash behind.
Last thing, once pellets get to around $8 a bag, you're getting into oil heat territory. That is, oil heat becomes price competitive, once pellets get up to around $8 a bag. And, given that you don't' have to do all that labor as with pellets, then there's little reason to buy expensive pellets when there is a shortage if you have oil backup.
No way would 3 tons = 4 of another. Doing the math I don't see it.So no way is 3tons of DF's equal to 4 tons of NEWP? I thought it sounded too good to be true... That's why I asked....
Thanks
I had to check your comparison list again, just in case I had over look those Pellets.
Hope there will be some up dates, this year
Good burning
Well it is good to see ya back since aug 22. I know those teenagers, can be busyNo way would 3 tons = 4 of another. Doing the math I don't see it.
8800 for DF and 8000 for NEWP. Is only a 10% difference. And thats the lab world not real world were you won't even see that. Once you factor in variables you probably only see approx 5% IMHO. Not even worth the extra cash if your frugal. But if you want to clean far less? The ash content is where the big difference is. Better than 50% less so you could go 2X as long between cleanings!! And this is where these pellets stand out IMHO. Cold spells where you can't afford to shutdown every few days to clean. Haven't the bit of extra heat doesn't hurt during these times as well.
If ya can't find the NEWP's go to the boxstores. They have Green Supreme's which are the same pellet.
Good luck!
I won't be testing much these days. Life takes turns and I have too many other distractions. Raising a teenager is one of them. Sorry!!
I know this thread is a couple of months old, but it was a good read. Oil price per gallon is only part of it. You have to look at how efficient your oil burner is as well. For me, in Jan, Feb and March, my past 4 years oil consumption shows me burning about 7-9 gallons of oil PER DAY! At even $2.50 a gallon, that's $20 in oil in one day. With pellets at $5.50/bag, if even if I needed 3 bags, that's only $16.50, a savings of 17.5% still, over oil...
