E
elkimmeg
Guest
the good news is my 30 year oil burner is still in good shape. I guess all the wood burning over the years put it to less use and strain.
reminder this is a cast iron Uitca Boiler I hit a new tims high in effeciency test 81%. I did the usual filter nozzel .but this year I learned that I cound clean the fire box and coils
with a wire brush and shop vac. I also learned to clean the oil screen in the oil pump. Another important part was leaning how to adjust the flame and air inlet.
The real trick was I gapped the electrode space .005 more the extra space makes the spark cross hotter. My previous best was 78%
MSG may boot this into which ever forum it should reside
Here is one other tip most trucker and heavy equipment opperators know this. There are products that enhance diesel fuel like HEET but also contain products that cleans your
fuel delivery system. If one was to add about 1/2 gallon to every tankfull. It works so well you may never need a tuneup, only an ocasional filter change.
The other advantage is burning clean and effecient all the time and a lot less carbon in your system and chimney. I know it is the time of year when your system should be cleaned and tuned
