I believe factory air settings are,
Primary fan gate fully open
Secondary two turns out on the bolts
I run my 200 with the small end of refractory towards the door.
I use a timer to shut off with coals left in the firebox.
Rake them over the nozzle
glow them with a torch
newspaper
kindling
newspaper
small splits
both doors closed
bypass open until internal flue temp is 200-250
Close bypass and gasifying
It takes less than 5 minutes from closing the door to hit gasification. If you have enough charcoal left it is so simple. About a ice cream pail will cover the nozzle well. That amount and about 2 or 3 minutes and you can have smoke free gasification.
If you have no charcoal, a couple of hand fulls of splitter trash will give you quick coals to ignite the Gases going through the nozzle with gasification around the 5 minute mark. You might have some very light smoke until you establish enough coals to ignite all the smoke/gases.
gg
newspaper
kindling
newspaper
small splits
both doors closed
gg
