Ok, I'm going to give you the information I have, I'll throw in a photo for guidance, and then I need you all to hold my hand and guide me the right direction.
I have a very ineffecient masonry fireplace that I'm looking to replace. At first I looked at inserts, but have since decided to go with a stove (the Scan 60 http://www.scan.dk/page/110?selected_id=1956&idx;=#1956). I'm going to be ripping out the tile work around the fireplace and building a new heat shield... I guess you call it... myself. I'd like to put the stove on soapstone tile, and have it vent through the back, and then up the existing masonry chimney. Once the stove is installed, I'd then frame in the existing fireplace opening (with steel studs) and put up some durarock, and then build a stone tiled wall behind the stove.
First, is this something that is common? That is to say, running a woodburning stove back up the chimny flue and boxing in the existing opening?
Second, the guy that gave me the estimate gave me two options, running either stove pipe, or a stainless steel liner back up the chimney to connect everything. The liner is a bit cheaper, but I'm not sure if it's a good option (he didn't have any double or triple wall pipe, but he said that he'd get me a price on that (the run up the flue is a real straight shot). Is this the right way to do things?
He also mentioned that I could run normal Stove pipe through the opening (between the stove and the newly enclosed fireplace), assuming that I use non combustable materials to seal up the fireplace opening.... Is this right? My walls are built out of cinderblocks, with a brick veneer on top of that, so I'm not too worried about the walls going up.....
Now, I'm pretty handy, and the prices he gave me seemed a bit high, but hey, not having to do all this is certainly worth something to me.
Labor- $425
Stainless liner kit- $599 or
Single wall stove pipe $257
My fireplace run is 18 feet from top to bottom.
One last word, there is no way I can convince my wife to vent vertically through our main room. The look isn't going to work for her. So out the back it is.
Thanks for the advice in advance guys, and I look forward to your thoughts.
Labor- $425
![Oh how I need your guidance on this wood burning stove install.... Scan 60. Oh how I need your guidance on this wood burning stove install.... Scan 60.](/talk/proxy.php?image=http%3A%2F%2Fimg253.imageshack.us%2Fimg253%2F4420%2Fdsc0411lo5.jpg&hash=068b2530bf02eeee13fea29c9195553f)
