My oil burning boiler went down overnight. The furnace guy from my church is already on a call, is coming here next.
The lower level of my house is down to +48dF already, I have something like 6-10 hours to be making BTUs downstairs, or face a massive frozen pipe repair when my baseboard heat pipes freeze up.
The good news is I just got oil delivered Thursday, most likely I have an air bubble or some sediment in the feed line.
The bad news is the what if side.
If my guy can't get me running in the next 8 hours or so, what are my options?
I have massive quantities of seasoned cord wood. Can I snatch an Englander NC-30 from Lowes-Depot and run it temporarily on the furnace stack? I think my guy can rig something up to the circulating pump so I can keep the water in the baseboard pipes moving. We wouldn't have domestic hot water until the furnace repair is finished, but the house will be warm top to bottom and it should save me a freezeup.
FWIW the furnace has a 6" outlet that is adapted up to the existing 8" stack. I could plug and play an NC 30 or similar 4' away from all combustibles pretty easy, it would sitting out in the middle of the garage on a concrete floor, and have pretty good resale value.
Alternatively I could grab a pellet stove and maybe exhaust it through the existing hole in the wall for the furnace air intake.
I could install a pellet burner in one of the downstairs bedrooms. It would be a massive project under the time constraint, but we have been talking about it as an option for years. It would cost us a bedroom if we ever choose to sell, it would take the house from a 5-2 to a 4-2 with office, or a troublesome hole to fix in an exterior wall to get back up to five bedrooms.
The garage floor is on grade. Existing stack is inside the insulation envelope on an exterior wall, punches through the roof above the second floor, total run is 18-22ish feet straight vertical starting about 6 feet above the garage floor.
Thanks in advance.
Thanks in advance.
