Adios Pantalones said:In some places you can bank energy in the grid on sunny days and draw out later like a battery system, and only use actual batteries for backup situations. That reduces battery cost, space, etc.
peakbagger said:I suspect that there would be a demand for a system with a small battery bank that could be switched from Gird tie to standalone in an emergency. Outback make a commercial system but it is limited to 48 volts which still requires big wires and most likely would require reworking a system that was designed as a grid tie only system. The trade off with a high voltage battery bank is that all the batteries are in series, so if one goes out the whole string may be useless.
dvellone said:Adios Pantalones said:In some places you can bank energy in the grid on sunny days and draw out later like a battery system, and only use actual batteries for backup situations. That reduces battery cost, space, etc.
Is that an equal exchange? Whatever you put into the grid you can effectively draw out with no expense other than your line fees etc.?
Adios Pantalones said:dvellone said:Adios Pantalones said:In some places you can bank energy in the grid on sunny days and draw out later like a battery system, and only use actual batteries for backup situations. That reduces battery cost, space, etc.
depends on where you are. the one I heard about- you could bank it up at 1:1 for some # of months. If unused after that they buy it at some rate (probably not what they sell at). This would be a great deal. The line fees etc are still the killah.
dvellone said:If the house is set up to be very efficient (which really should be a large part of any discussion regarding solar, wind or water power and any level of energy independence) the demand on the batteries is greatly reduced.
woodchip said:It used to be reckoned here that an acre of land would be enough to feed a family of four for a year.
Personally, I'm a bit sceptical about it as a couple of years ago I did an experiment whereby I grew a square yard of wheat and was barely able to make a loaf of bread in the Autumn.
I went back on the grid for bread after that ;-)
