+ 1 especially the warm and fuzzy partsmokinjay said:I think they run better on 93 seem to start a little easier and a little better throttle response. On the very large cuts I also think it keep the rpm up may all be in my head but makes me fill better. (all warm and fuzzy)
basswidow said:yeah - ethanol is bad.
What about if you run 93 - could cause your saw to run hotter or lean? Or is the running lean merely a function of not having the oil mix right?
Do you run 93 in all your 2 stroke equipment? I've just been using 87. Not sure if I need to change that or not?
Deere10 said:I only run 93 in my saw. Never any problems. Thats what the dealer said to run in the Husky and it loves it never one carb problem.I also mix synthetic 2 stroke oil with it...... OOO no did i open up a whole can of worms there??
I'm lucky, one of only two gas stations in the whole country that sell non-ethanol gas is about 8 miles from my house. People will drive from 30 miles away just to get the non-ethanol gas for their 2-stroke and outboard motors (even 4 stroke outboards!!). Ethanol is the small engine and outboard mechanic's friend--a recent story in our local newspaper had an outboard motor repair shop stating that over 70% of their business comes from ethanol problems..........Peter SWNH said:FWIW, I run 93 in anything that has a carb. From my experience, it seems to run better and doesn't go stale as fast as 87.
bogydave said:Octane: (broken link removed)
Octane additives in gas that is mixed with oil, no benefit, actually research shows the opposite.
No more "bang for your buck" to buy high octane for 2 cycle engines.
It does burn slower & run cooler but the additional additives has a tendency to gum up pistons. Regular detergent gasoline is actually better. From some research I read for 2 cycles.
Fill / top off the saw when you are going to use it, (fresh gas) don't fill it & let it set till next time you'll use it.
Keep your mixed gas in a sealed container & as cool as possible. Ever notice how the plastic jugs swell in the sun when out cutting? (my 2-1/2 gallon jug now holds 3 gal)
As soon as you open the container, whoof, some high end are gone. If you smell it, it's flashing off. After 2 months or so of no use, dump the gas out of the saw & put in new .
Empty the tank if your not going to use you saw for a while.
My buddy was a lab tech of the Tesoro refinery here, told me unless it's a high performance sports car engine, waste of money. Fresh gasoline is more important.
stee6043 said:Lot's of fancy answers....all I can say is that I run 87 in my MS 310. She starts fine, runs great and she cuts wood. I like high octane beer, does that count for anything?
smokinjay said:stee6043 said:Lot's of fancy answers....all I can say is that I run 87 in my MS 310. She starts fine, runs great and she cuts wood. I like high octane beer, does that count for anything?
yep as long as your getting the warm and fuzy part... but for real sthil has moved there min. octane rate to 91. I have more in my saws than trunk and the saws dont eat much so I run the 93... and there is some who run 100
Tony H said:You need to run what the MFG states in the manual I think Stihl says 89. Since octane is only a figure used to express the resistance to detonation running anything higher than what's needed is a total waste of money. The oil companies have long tried to promote the higher grades ..... guess why more profits.
Fresh gas makes a difference and the chemicals like Stabil and Sea-foam do help to preserve the gas.
Just so you don't think I making this up I got the info from my BIL who has been a chemical engineer for Shell oil or whatever they are called now for the last 20 years. With modern cars it's even a little different , if the MFG says premium required vs recommended . Because the computer will adjust the timing the car "recommended" will run fine with regular with a little reduction in performance on full acceleration on the other hand the "required" car will probably suffer detonation on regular gas.
DanCorcoran said:Okay, so I have a gallon of old (stale) fuel mix. How do you dispose of it?
