Ocean drift wood ok?
ruserious2008 said:
Interesting question- my first thought was "what happens to salt chemically in a wood stove?" Does it just go up the stack as sodium chloride?
Any chemists on the forums? I did find this at Ask.com "Sodium imparts a bright orange flame when lit. However, little can be done to the chemical structure of NaCl as it has a high melting point of 800C or ~1400F."
Not one to believe something just because its on the internet but by that standard I wonder if it would just wind up in your ashes unless you have a major overfire and then I think you've got bigger problems than giving your stack high blood pressure:)
I also wonder how much salt is really in the wood? Again need a chemist but wondering if due to molecule size or something else is it possible the wood can absorb the H2O in sea water but not the salt? Does it give off bright orange flames that you don't see with non driftwoods?
And probably makes sense to follow your manual but then again you'll see some tell you not to burn pine and that's a whole other thread:)
Anyway, just thinking out loud
If you would like, I will save some white oak pilings that have soaked for 75 years.
You can burn them in your stove and see if the "myths" are true.
Interesting that you don't think any part of your wood fire reaches 1400 degrees.
Dune said
"Interesting that you don’t think any part of your wood fire reaches 1400 degrees. "
Good point Dune. Guess I was just thinking stack temps. But I guess my conjecture still applies - what happens to the sodium chloride when it gets exposed to 1400+f if it does in a wood fire?
With my limited chemical background I know from work experience that a nasty chemical like Silane , Sih4, burns on contact with air (due to the O2 in our air) but under controlled conditions it deposits Si (Silicon) on wafers as part of the process of making computer chips and the by product is 4 molecules of Hydrogen which are no where near as nasty as the SiH4 it started out as so my point was/is don't assume that salt just goes up the stack as salt - maybe it does but maybe it doesn't go up the stack at all or maybe it goes up as something else ( maybe less or maybe more nasty) or maybe my limited knowledge is getting me in trouble:) Love to think out loud and challenge conventional wisdom and learn so someone else chime in:) Friendly conversation is all I'm trying for :) Intrigued now about what happens to salt at what temps????
double-post. <snip>
Frostbit said:
In my case, no other choice. So that is what it gets. Heating fuel is $5.83 a gallon, what's a guy gonna do otherwise?
Is is a little tough heating with firewood where there aren't any trees.
As far north as you are, you probably can't get any freshwater driftwood, and if ocean wood is all you've got, and you want to burn it, then one option would be to go with barrel stoves with sand in the bottom and cheap stovepipe, and replace as needed.
Other options include exploring locally available alternative energy options. Wind generators coupled with electric baseboard are worth considering, especially with the tax credits available at this time.
Another option is looking at improving the energy efficiency of your shelter. I'm sure you've heard the quote (I paraphrase): "In the old days, we built our houses underground and buried our dead on the tundra. Now we bury our dead in the ground and build our houses on the tundra, and we haven't been warm since." Are you in one of the HUD-housing structures? Sun orientation, insolation and passive heat storage, insulation, ventilation--all of these things are easier for most people to do something about than are shipping costs and oil prices.
If oil prices continue to rise, shipping may become not only more expensive but less frequent as well. That would seem to me to be the course of wisdom, focusing on becoming energy independent in a locally-appropriate way if you're there for the long haul. Burn less oil, and you have effectively dropped the price of oil.
We each balance the pros with the cons in making a decision about where to live; if the quality of life/employment opportunities/family connections counterbalance the realities of high shipping costs where you live, then you work with what you've got. If they don't, you move--preferably to someplace with trees if you want to heat with wood.
[/quote]
Post#22 (above) does a good job with the chemistry.
You will note of course, that the intense heat in a firebox accelerates any reaction between the metals present and the acid produced by the salts in the wood.
If I remember correctly, every rise in temp of 50C doubles the rate at wich reactions occur.
I've always heard not to burn it and heard of people who live on the beach, or have beach cabins, rusting out stove pipes from burning drift wood. When I bought my insert the guy at the store said there's one thing they always tell people NOT to burn, and that's driftwood.
Not sure if it was mentioned previously in the thread, as I only skimmed it. But the particular stove pipe i'm considering says burning driftwood will void the lifetime warranty. So I'd assume it has some type of damaging effects.
I would think that adding ground pepper to saltwater driftwood would give you perfectly seasoned firewood...
Now there's a mind at work. ;-)
:lol: Well done.
Well being the curious type I posted a question about this on a chemical forum. As many varied answers there as here but I think I got this out of it:
The salt, NaCl, does not change in the fire and deposits as is in the ashes. However, magnesium and calcium in the sea salt does create HCL though not sure in what quantities. That was my original hangup with my limited chemistry background- didn't see how we would wind up with HCL from salt. Having worked with HCL in the semiconductor industry I can tell you that you don't want to be breathing that stuff in any amounts so that alone now puts me solidly into the "don't do it category" for burning saltwater driftwood . It was used to etch glass -SiO2- off of wafers and anything else it deposited onto such as the quartz tubes used to contain the reaction that created the glass (used a really cool and nasty gas called Silane, SiH4, that bursts into flames on contact with O2. So really easy to see a leaking pipe of the stuff if it doesn't explode, it'll be on fire:) But I digress....
Other interesting side discussion was about the powder they sell to put on your fire to get rid of creosote where it was said that creates HCL and that's probably how it "supposed" to work.
Anyway here's a link to the thread for those interested
http://www.chemicalforums.com/index.php?topic=51801.0
We do have at least one forum member who lives, I think, near or in Nome and he does burn driftwood but that is about all he has.
If it were me, I would not burn it unless there was no alternative. One can see many examples of what salt can do to things.
Greetings from a (reformed) drift wood burner... I posed a similar question awhile back when we were deciding what wood stove to purchase given that we live on the NW coast of Alaska where the only trees are found washed up on shore. Try searching for the topic, "Western Alaskan seeking stove advice for burning driftwood," (12-03-2009), followed by "Update from NW Alaska driftwood-burning woman," (9-30-2009). Followed by our experiences, including photos, I'll post here:
We have a Pacific Energy Alderlea T-5, and burn driftwood well-washed by summer rains, along with wood pallets and lumber scraps. We have also been able to mix in a small amount of standing dead spruce gathered at the end of a seasonal 70 mile road. We only use the stove as a supplement to two monitor oil stoves, and only burn several cords a winter. In the past two winters we figure we have burned a total of 3 cords of dry, split driftwood and are now seeing serious corrosion on the bottom of the baffling system. It has corroded straight through in a few small places, but is still functioning as designed. Nonetheless, this is why we purchased the PE stove - so that we can replace the baffling system when the need is apparent.
Given the corrosion we have seen after a relatively small amount of driftwood burned, I think we will likely limit ourselves to pallets and lumber craps after this winter. Maybe it will be cause for a few long-distance snowmachine (called snowmobiles everywhere but Alaska) trip to haul home several loads of that standing dry spruce.
I do have a number of Native friends who have long burned driftwood in pre-EPA stoves who don't see what the fuss is all about.
I hope this isn't too discouraging. I know we'll miss harvesting wood by driving the long sand beaches listening to the surf and gulls, and maybe we'll still mix a bit in, but we'll be very careful in our selection and will continue to watch the stove carefully.
Good luck - and my continued thanks to everyone on this website for their thoughts, suggestions - and humor!
  • [Hearth.com] Ocean drift wood ok?
Hi Sue, thanks for the input. Do you have an abundance of driftwood available?
If so, if may be worth considering a masonry heater such as a russian or finnish fireplace.
Sue, we saw some pictures that showed lots of wood piled up after some of those high winds. I'll bet that made lots of folks very happy. And for what it is worth, Alaska is not the only place that has snowmachines! Most people in northern MI also drive snowmachines. Others drive snowmobiles.
Good luck to you for keeping warm this winter. You live in a very cold place indeed. Well, you do have the Iditarod for excitement. lol
Hehheh . . . I was wondering what the heck my sister was talking about when she moved to Alaska and started talking about snowmachines . . . never heard it called that . . . around here its sledding or snowmobiling.
Funny Jake but I almost mentioned you in that last post that you would not know what a snowmachine was! Probably plenty of folks think it is a machine for making snow! lol
