Oak slab wood
gzecc
5,128
NNJ
Just picked up a small trailer load of oak slab wood. Unfortunately its not good enough quality to save for anything but firewood. It was tough cutting it up. It was stored inside for a couple of years. CL free!
Save it for Jan. Doesnt burn as long as hedge but will run with the btu out put.
We've found the best or easiest way to cut up slab wood is to make a sawhorse. Some call this type of sawhorse the H design; some call it the alter! Made right you can stack maybe 10 or more slabs at a time and then cut those 10 all in one cut. I like to make it long enough to make 2-3 cuts before having to move the slabs. I've also seen people use a front end loader to stack slabs on and then cut. For real ease, a buzz saw works great but few have one.
I guess it really wasn't slab wood. It was rough cut lumber from an oak and cherry tree. I just cut it hanging off the trailer while I was off loading.
Ah, this makes sense . . . read your first post and was thinking, "It's slabs . . . what else would they make out of slabwood?" This makes a lot more sense when you say it was rough cut lumber.
