Dune said:Thistle said:http://en.wikipedia.org/wiki/Lignum_vitae One of the main woods that used to be called Ironwood,Lignum Vitae is the world's densest wood,at 83lbs/cubic foot & specific gravity at 1.32.Its main use until after WW II was bearings for propellors on ships.Also pulleys & blocks used in rigging on wooden ships.Self-lubricating,with a waxy resin that lasts decades underwater.
Nice link, thanks. I once owned a 60' steel workboat. Imagine my surprise when I discovered it had WOOD propeller shaft bearings! They lasted so long that when one finaly did need to be replaced, I used lignum vitae again, only because some of the old hands around the dock knew what it was and the whereabouts of the stock. (Flyer's Shipyard, Provincetown Mass). Flyer supplied the material and shaped the bearing himself, and IIRC was over 80 years old at the time, many years ago.
You're welcome. About 10 yrs ago I replaced the Cool Blocks graphite impregnated phenolic resin aftermarket blade guides on my Delta 14" Band Saw with ones made from a small piece of 2"x2" Lignum turning square from my scrap box.They're 1/2" square,3/4" long on upper,1/2" square & 1" long with 45 degree cut ends on lower.They can be adjusted to literally touch the sides of the blade,unlike other soft steel or other synthetic guides,making your cuts more accurate.
These are the same material that were used in the first massive band saws used in mills over 100 yrs ag
nly took about 10 minutes & arent even close to being worn out yet.
