Methinks FIL and I would be having one of those, "Come to Jesus" type discussions and there would be no hesitations and I would guarantee he would understand my feelings when it was all over....
Methinks FIL and I would be having one of those, "Come to Jesus" type discussions and there would be no hesitations and I would guarantee he would understand my feelings when it was all over....![]()
Oops, my typing overshot my thinking.L O L. I presume you're not talking about your car?
I was talking about Mom. She moved in over a year ago.
Years ago I had a small house with a big stove in it. I don't burn this way anymore, but back then I used to put a load of dry oak on top of coals and turn the air way down. It was just a long smolder really.
Anyway, I had this one stack of cottonwood that I used only for starting fires.
So, my father stops by one day when I wasn't home and notices that the stove is down to coals. He packs it with cottonwood and shuts the air way down.
Later, when I get home, I open the door to the house and smell this overwhelming creosote stink. I go look at the stove and there is a LAVA FLOW of creosote coming from the bottom of the stove pipe and crawling across the top of the stove and down the sides!
Lessons learned: I don't "smolder burn" anymore and the stove pipes should be assembled in the proper manner as indicated by most stove manufacturers.
Incredible that the house never burned down or you never have a bad chimney fire!
I was going to ask you about the "lava flow" and if you were sure you had your pipes going the right way....but I see in the bottom of your post you figured it out. when I was a rookie, I put the pipes on backwards ONCE. didn't take long to figure out it wasn't the right way. amazing how many folks initially hook them up backwards...............Later, when I get home, I open the door to the house and smell this overwhelming creosote stink. I go look at the stove and there is a LAVA FLOW of creosote coming from the bottom of the stove pipe and crawling across the top of the stove and down the sides!
If you have creosote running out of your stove pipe you have bigger problems then incorrectly installed stove pipe, what you have is a ticking time bomb.I was going to ask you about the "lava flow" and if you were sure you had your pipes going the right way....but I see in the bottom of your post you figured it out. when I was a rookie, I put the pipes on backwards ONCE. didn't take long to figure out it wasn't the right way. amazing how many folks initially hook them up backwards.
yes it is, but for a lot of folks, when they first started burning there was no forum or internet to help answer questions. it was trial and error...sometimes mostly error. thank goodness there is this "well of knowledge" on almost every topic imaginable associated with wood burning.If you have creosote running out of your stove pipe you have bigger problems then incorrectly installed stove pipe, what you have is a ticking time bomb.
The information was out there but in books and magazines so no quick fix but that is where I learned about dry wood and flue temps 35 years ago.yes it is, but for a lot of folks, when they first started burning there was no forum or internet to help answer questions. it was trial and error...sometimes mostly error. thank goodness there is this "well of knowledge" on almost every topic imaginable associated with wood burning.
Years of burning really dry hard wood before that, so I never had any idea why the pipes needed to be a certain orientation. I cleaned the chimney once a year and it barely needed it. Then there was, what will always be referred to in my family as - "The Cottonwood Incident".
