I have had folks use them both ways. Running it through another heat exchanger is do-able but most folks try to minimize the number of heat exchangers
in the loop.
in the loop.
yes sure, but what is the advantage of DHW through the storage in the off season?...maybe low consumption... in my house there is no such thing as low DHW consumption.I think you can do either Skyfire..
yes sure, but what is the advantage of DHW through the storage in the off season?...maybe low consumption... in my house there is no such thing as low DHW consumption.![]()
We have people heating large tanks, which, of course, allows you a lot of capacity. IF, the standby loss is reasonable, it can be done efficiently. You then have a lot of
DHW.
The heat pump only delivers 6-7k btus/hr, and with a well insulated tank, just replenishes the DHW usage and (hopefully) modest standby loss daily.
confused I am....so the HP returns from and supplies to your storage?
Why not directly to the indirect DHW...? I am sure I am missing something here...
? Then what temp can you get your indirect tank up to?I know what your talking about, my 17 year old daughter will stay in the shower till my 52 gal. buderus DHW runs cold.yes sure, but what is the advantage of DHW through the storage in the off season?...maybe low consumption... in my house there is no such thing as low DHW consumption.![]()
. This greatly reduced the operating time of my mini splits over the summer.Kopeck..What temp do you get your 850 gal tank up to? 130? Then what temp can you get your indirect tank up to?
If your storage or your Garn are in the basement you'll need a hell of a lot of insulation on it in order to not keep re-circulating the warmer air coming from the heat loss of your tank. That extra heat is really noticeable in the summer when you're trying to air condition the living space. I have 4 inches of foam on my storage tank and the heat loss filters upstairs enough so I need to run my mini splits more days during the summer.
What I did was just heat my Superstore with the Geyser and blow the basement air up to the living space when the basement air dropped to about 62. This greatly reduced the operating time of my mini splits over the summer.
How would you control that? Would you install a "make on rise" aquastat when the water reaches 120 or so and let the LP take it from there?So the HP will get me partly there and then the LP burner will top off.
You could also plumb it so it doesn't use either the indirect coil, or storage - you could T off your fresh water inlet & hot outlets to facilitate circulation. Same as you would hook it up to an electric DWH tank. If one way was easier than the other. Or maybe you're not talking using the indirect coil...
I had thought about a HPWH replacement for my propane fired unit, but the cost/ROI had turned me off till the propane unit gave up the ghost.
I like the idea of being able to seperate the tank from the guts. That way each part is only replaced when necessary. In addition to being able to fire up the unit on propane when we have a ton of additional people in the house to get faster recovery (holidays).
Ran the numbers and it looks like assuming propane is 2/gal and electric @ 10/KWH , payback is about a year.
Given this ROI why are more people not jumping on this? Hook up looks very easy with less than $50 (guess?) in additional plumbing parts.
Has anyone installed one of the ebay Nyletherm1's on a propane fired HWH? Were you pleased with the results?
Also...who is Tom in Maine? I've seen him mentioned a number of times. Is he the one selling them on ebay? What is his hearth name so I shoot him a note if this looks like a go.
