I searched the forums and could not find anything, but it looks like on the VC website they now have a new insert: The Montpelier 2. I have the older version (Montpelier) and have been very happy with it. Looks like VC made a few changes to get it to <2g/hr for the 2020 emissions standards. Changes are pretty minor as far as I can tell. They put a blanket over the baffle, downsized the firebox a bit (2.6 to 2.4 cubic feet), and changed the large, single piece refractory bricks, to standard replaceable fire bricks. They also moved the primary air adjustment lever, which to me indicates that they likely moved where this air enters the firebox.
www.vermontcastings.com
I know a lot of folks are VC haters due to their terrible experience with the catalytic stove line, but I can say that my insert, which is a simple secondary tube insert, is a joy. I heat our 1500 downstairs in sub zero temps and get long burn times (up to 10 hours when I pack the firebox). I suspect the new version will also be a good insert based on the very minor modifications that were made. Glad VC decided not to add a catalyst and instead just tweak the older version. I was disappointed to see that Jotul already went catalysts in their big stove (oslo 500). Seems like stove manufactures are using catalyst as a bandaid to make their stoves hit the 2020 standards instead of redesigning the stove from the ground up so that it can function to utilize that catalyst to generate heat like BK did. At least that is my take on it. I look at the new stoves getting catalyst just before 2020 mandates (Jotul, PE, Hearthstone, etc). It looks to me like they all took there stoves and just crammed in a catalyst near the exhaust port. Likely all the heat just goes up the stack and the heating numbers (BTU and burn time) that I have seen on the spec sheets all reflect it.
Montpelier II Wood-Burning Insert
The Montpelier II wood insert highlights large, unobstructed views of the flames, turning your existing masonry fireplace into an efficient centerpiece.
![www.vermontcastings.com](/talk/proxy.php?image=https%3A%2F%2Fwww.vermontcastings.com%2Fimages%2FVCG%2Frwd%2Ffavicon.png&hash=65853141e0a1be82dff64387a4de42d0&return_error=1)
