After reading the thread, I'm with firefighterjake and others - seasoned wood is a relative term, and it sounds like yours is less seasoned than more. I found that if I could get a large number of small splits (1 to 2 inch) criss crossed into the stove during the first fire, I could get the stove hotter. Then the next load of small splits would take quicker, burn hotter, and the stove would regain the higher temps (600-750 on my insert)
I am in a similar situation this year, my wood was "summered" vice actually being seasoned for more than one season. I often have to place a stick or two of kindling under a fresh load of wood to raise it up off the coals to get the fire to restart - it lets the air circulate better, and in essence the better air circulation dries out the wood in the firebox quickly. Be careful though, as I have seen mine climb really quick when I placed a few good sized splits into it, raised up on kindling, once the flue and stove were primed.
Getting higher temps on the stove will pay off fourfold in the heat you get into the room - radiant heat output (in a perfect world) is a fourfold product of the change in temp. A 20% increase in absolute temperature (measured in Kelvin, so 400 F increased to 570 F is a 20% Kelvin increase) will get you double the heat output. So, to get more heat out of the wood, burn it hotter - if you can raise the newly added wood above the coal bed with a couple sticks of kindling each time, you may get that heat you are looking for. The stove isn't a perfect emitter, but you get the idea that higher temps give disproportional increase in radiant heat output. A similar result will occur for convective heat as well (different ratios and formulas, but still disproportionate to temp increase). Someone out there will correct me if I'm out to lunch I suspect. :roll:
That has been my trick this winter for dealing with my less than seasoned wood. My next trick will be buying 4 cords (the 4ft x 4ft x 8ft kind, in case there is any question) in February to pile up in my yard for next year.
