no it looks the same. that handle you are suppose to hook around the bolt that is broken off and push the handle down to close and latch the ash door. DON'T use it like that or you will melt the inside right out of it
Right now I shove a heavy stone flower pot against the ash door to keep it sealed. It holds it nice and tight. I would prefer to fix it properly. But getting information on it's measurements/material or even finding pictures of the thing has been impossible.
So does yours use the same mechanism for latching the ash door?
Once I know what kind of bolt it's supposed I could either try drilling and tapping the hole (or get one of those threaded inserts they use on engine blocks). Or use some high heat epoxy (I would check the temps first and make sure it's within the epoxys range).
just looked on the woodmans parts plus web site they don't list it. you could try calling them by phone they might get the screw for you. they are very nice and helpful. they are the people that put me on to the wood tech at hearthstone in vermont and had a nice long conversation with jim casavant he said he helped design the stove. hope he still works there
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
