Krogoski
The smoke issue is interesting. I haven't been able to find NEILs in Indiana, only the local "bio-brick", GrenHeat. I have experienced heavy smoke, but only for an hour or two from Cold and 15-20 minutes on coals. I've also not experienced the runaway you have.
I have loaded 80 pounds of the GrenHeat blocks numerous times, and it's always a RonCo affair, "Set it and forget it."
The smell outside is different though. Normally, on mixed hardwoods, I'll get a slight wood/charcoal odor. The GrenHeat blocks odor remind me of a blacksmith shop.
I one thing I have noticed is that the amount of smoke at start-up changes with how the bricks are loaded. if all the bricks are lined up, neat and orderly, then I tend to get heavier smoke than if they were loaded with a running bond pattern. I have also noted that the whole load burns, pretty much evenly if lined up, and front to back with running bond.
I know that Running bond would be impossible with NEILs, but how about E-W loading? Lighting the front log only. I wonder if the issues you are having are due to the large air gaps created when stacking round objects. The incoming stove air is then pushing the heat down the channels created, causing more and more fuel to be released (smoke). The same happens in the "log cabin" stack you tried first. Too much exposed surface area, creating too much free fuel that just overwhelms the capacity of the cat. Just an Idea...
Krogo.
Krogo.
