Slow1 said:I had one tarp secured on a pile for a year as a bit of an unscientific experiment to see if I could tell any difference in drying rate (I couldn't).
Slow1 said:Just curious here - all you folks using plywood or other solid roofing materials. Has anyone tried screwing these types of material into the stacks instead of putting splits or rocks on top of the 'roof'? I realize that you would have to put quite a few into different splits all over the place, but it seems the weight would help keep the roof down and would be less likely to slide off from sheer force of wind thus requiring the wind to actually lift the roof off. More work, but if you are going to leave it for months or years, why not?
I'm watching for some free recycle-able material of this sort to put on my stacks and am debating if I would try this approach so looking to see if it has been tried...
Battenkiller said:Slow1 said:I had one tarp secured on a pile for a year as a bit of an unscientific experiment to see if I could tell any difference in drying rate (I couldn't).
Just curious, what method did you use to determine the drying rates? How long a period of time did you keep records for? Seems to me that covering would make little difference in drying rates in the beginning when the wood is very wet, but just might make a difference at the end when you are bringing it down to the final stages of dryness.
Battenkiller said:As far as covering material, you might drive around the country looking for stacks of old roofing on farms nearby. Farmers around here are pretty smart, thrifty too. Never throw anything out. Maybe you can score some beat up used metal roofing for a few bucks just so they can get something out of it. You'll need to weight it down, though. A good, strong wind can pick the stuff up and send it off like a kite.
WoodPorn said:GOOD SCORE!!
Make sure you support the middle or rain/snow WILL sink it right down in between the rows (unless you stack single row)
WoodPorn said:I thought the idea behind a Holtz Hausen was to create a chimney effect and draw the air in and up through the center (theoretically). If this is the case the rubber may not be a good idea. I could be wrong,.......... just ask my wife!
GolfandWoodNut said:I am with you Jake. Never saw any smoke coming out of my HH chimney. Now when I build one I find the center is a conveinent place to throw the odd sized pieces etc. You cannot beat the look of HH if it is built right, but chimney efffect, don't bother to stack vertical in my opinion.
