A lot of stoves stop the power to the augur motor when the hopper is open some even have switches that require the firebox door be closed before the stove will start, and so forth.
kykel said:my point was that it was working properly - hood open off hood closed on but auger not turning
kykel said:When I turn on the stove the lid is open. when I put the lid down you can clearly hear the auger motor go on. open lid motor stops close lid motor goes on. I assume the fuse is for the motor so why does it run and auger not turn? There is no jam because if you jump it out they both run fine. smokey thought maybe not enough voltage being delivered to motor
flynfrfun said:Glad you got her going again! Look on the bright side...now you know a lot more about the stove. Better to know now, than to be learning during the dead of winter in emergency mode.
flynfrfun said:SmokeyTheBear said:flynfrfun said:Glad you got her going again! Look on the bright side...now you know a lot more about the stove. Better to know now, than to be learning during the dead of winter in emergency mode.
I suspect that by the way the boss lady was acting this may have been emergency mode.
Ha! I forgot about that Smokie, you're right! :lol:
