Just installed a vermont castings montpelier fireplace insert. followed directions in the guide to warm the unit slowly, lit a small fire to heat up the pipe going up the chimeny. Smoke filled the unit and fire went out unless the door was cracked then it came back to life while smoke billowed into the room. Opened windows like other posts said for negative pressure - nothing changed. The unit is hot enough for the fire to ignite itself again, however the fan doesn't kick on blowing heat into the room. Directions say to test prior to installation, but later say the heat from the fire will kick it on.
How do you test the fan without a fire going?
It's not getting any air through the air intake. Door must be open.
It's a new unit, so nothing is clogging the hole to the chimney. If anyone has an other ideas, i'd love to hear them. Right now, trying to get the smoke out of my house!
