Hello Everyone,
Not new to the site as I usually am posting about pellet stoves. But in the last month I installed a Englander 28-3500 wood burning furnace in my 2 story carriage house. The furnace is on the bottom floor on concrete, in a small furnace room with required firecode sheetrock, fire door, ect. Installed double walled black pipe from furnace up through the second floor and the double walled stainless class A through the roof and 10' above the roof to get the required 24" above anything within 10' deal. Actually went just a little higher than required.
I have awesome draft and get the wood burning nice. Burning wood is new to me so I have a few questions. On the front of this unit is a temperture guage and it has a designated burn area marked off of between 275 and 575 for the range I should stay in. Too low and you create creasote, to high you over fire. I had about 15 burn days so far and getting used to this furnace. The manual for the stove and post on here state that I should get about 6 to 8 hours of burn out of a load of wood, filling the furnace. I am lucky if I get 2 hours. I am continually monitoring the burn and closing the draft controls to keep it above 300 degrees. It has to be burning pretty strong for me to get it above 350. I get it so that the draft control on the ash door is almost closed and the chimney draft is 4 fifth closed. If I close any more the temp goes below the "Burn range" on the guage. Having it set like this gives me about 2 hours before the wood is down to ashes. What am I not getting here? The wood is Ash and Cherry, cut in late October. I don't think it is because the wood is too dry. Any thoughts? I was thinking that the temperature guage was broken but the thermostat (seperate from the temp guage) on the unit doesn't turn the circulation fan on if the guage reads under 275.
Another question. Because this is a garage and I am only working during the day, and am only getting 2 hours of burn out of a load of wood, the fire goes out every night after I finish work. So all the start up and cool down time this system gets every day has plenty of time in the "Creasote making" temperature range. How concerned do I have to be about this? How often should I be checking the insides of the chimney pipes? My plan was, if I get the 6 to 8 hours of burn per load, to fill it before bed and keep it burning 24/7 and not have this amount of down time. It ain't workin' out dat way right about now. Thanks for any suggestions.
