O
oldspark said:I want to make a comment but I do not know where to start! :cheese:
havermeyer said:Pagey said:Welcome to the forums, bill. I'll throw some food for thought out that might help a new comer, and others will correct me where I'm wrong. First, as far as the air control on your stove goes, think of it like this: it basically shifts the balance of air in your stove. When you initially build a fire and the wood first begins burning, this is "primary" combustion. The wood is still boiling off moisture so that it later reach a higher temperature and release more volatile gases. The air control when open fully will supply more fire towards the bottom of the firebox to aid this primary combustion.
As the wood heats up and the moisture is boiled away, it can then achieve higher temperatures. It will release volatile gases that, if hot enough and supplied with enough air, will burn and can contain up to 50% of the heat value in a load of wood. As you close down the air control, the balance changes, and more air begins to come into the top of the firebox via the burn tubes in the baffle (assuming your stove does have burn tubes). This shifts the balance of air away from the bottom of the firebox (primary combustion) and towards the top, where it can meet the volatile gases and ignite them for "secondary" combustion. You'll know it when you see it. Nice, rolling flames across the top of the firebox. They can vary in intensity and appearance, but you will know them when you see them. When you have strong secondaries, you will usually see a significant rise in surface temps of the stove.
Some users can close the primary air control all the way on their stoves and maintain active, secondary combustion. Others have to leave their air control open an 1/8 or 1/4" or so. You will learn the "sweet spot" on your stove just as I have on mine.
Another thing to keep in mind is that modern EPA stoves like to burn in "cycles" rather than by adding a split here and here. Once you've got a coal bed that is established enough to easily light off a load, put in the amount you'll need for that fire's heating needs. If it is milder weather, you may choose a few small splits placed loosely together for a quick, hot "flash" fire. If you in January and getting ready for bed, you may load up a full charge of oak, packed tight for an overnight burn. But in either case, it's best to establish the fire size/intensity you need at the time and then let it burn through that cycle without adding more splits here and there. Once you're down to charcoal again, open the primary air full, rake them to the front to get nice and hot, and reload as needed.
A final thought: if you did indeed have a chimney fire, I would take the time to inspect my liner for any additional deposits. Did you say how long the wood you are burning has been cut/split/stacked? It often sounds like overkill for new burners, but most agree that wood that has been cut/split/stacked (not sitting in the round, still) for one year is the minimum you want to operate an EPA stove with. We'll be glad to help any way we can.
Nice summary!
As with the OP, I've been also a bit confused about what is the best setting for the air control to avoid smoldering fires and creosote buildup. My stove will be installed Nov. 1 but trying to learn as much as I can before the first fire
From what I've been reading, restricting air flow too much can cause creosote buildup. Is this because you are causing the stove to burn at a lower temperate (and decreasing the temperature of the flue) or because you don't have 100% combustion and the fire is now releasing more unburned particles? Either way, it seems like you are asking for trouble from doing too many overnight burns... or is there a sweet spot for overnight burns so the fire burns at decent rate?
Also, are overnight burns mainly secondary combustion since you are closing the air intake so much?
-Andre
oldspark said:I can't stay quiet any more, this is pretty much what I was talking about and have been off and on for the last 6 months, look up any article about chimney saftey and they recomend a flue temp sensor. This is not saying you run your stove with it (never claimed I was), it is just a saftey device so your pipe dont glow or worse. So think what you want that is all I was ever saying.
billc4 said:. . . For me I guess I will have to overcome the fear of dialing down the primary air control and going with a medium or lower burn rate after the fire is established.
I would have more fear about destroying my stove pipe and chimney . . . and more fear of going through my stockpile of wood . . . far before I would worry about dialing down the air.
About the worse thing that could happen if you dial down the air too soon is the glass blackening up . . . well scratch that . . . I suppose you could dial down the air too soon, the glass blackens up, you've wandered off somewhere
for a long time and then you come back and open up the door to the firebox and the sudden rush of air allows the fire and the combustible gases milling about there to burst into flames in a particuarly explosive fashion . . . however, I suspect this second scenario to be extremely unlikely given the fact that you see pretty cautious and don't strike me as the type of person to wander off from the stove unless you know it's burning OK.
More likely what would happen is that the glass starts to blacken up . . . and you open the air control . . . fire bursts back into flame . . . you let the fire go for a bit . . . and then turn down the air a few minutes later . . . and when the fire continues to burn . . . you try turning down the air a bit more . . . and then you achieve the secondary burn . . . and start panicking when the Portal to Hell appears in your stove . . . at which point you get on line and write out a thread wondering if it is normal to have the Portal to Hell appear in your woodstove.
For peace of mind I will have the same company come out to sweep/inspect the chimney. That did the cleaning a month and a half ago.
I think I would do this as well . . . just to err on the side of caution.
Bill
I remember you telling me that a while back, my questions seemed to confuse some people and we had different opinions, I am going to stay away from posts like that and just see what other people are doing and learn on my own.firefighterjake said:oldspark said:I can't stay quiet any more, this is pretty much what I was talking about and have been off and on for the last 6 months, look up any article about chimney saftey and they recomend a flue temp sensor. This is not saying you run your stove with it (never claimed I was), it is just a saftey device so your pipe dont glow or worse. So think what you want that is all I was ever saying.
+1 . . . as mentioned I tend to use my flue thermometer most often to know when to start closing the air control to achieve a good secondary combustion.
oldspark said:I remember you telling me that a while back, my questions seemed to confuse some people and we had different opinions, I am going to stay away from posts like that and just see what other people are doing and learn on my own.firefighterjake said:oldspark said:I can't stay quiet any more, this is pretty much what I was talking about and have been off and on for the last 6 months, look up any article about chimney saftey and they recomend a flue temp sensor. This is not saying you run your stove with it (never claimed I was), it is just a saftey device so your pipe dont glow or worse. So think what you want that is all I was ever saying.
ya, keep posting. I like it short & sweet vs long & not as sweet by verbose dillutionfirefighterjake said:oldspark said:I remember you telling me that a while back, my questions seemed to confuse some people and we had different opinions, I am going to stay away from posts like that and just see what other people are doing and learn on my own.firefighterjake said:oldspark said:I can't stay quiet any more, this is pretty much what I was talking about and have been off and on for the last 6 months, look up any article about chimney saftey and they recomend a flue temp sensor. This is not saying you run your stove with it (never claimed I was), it is just a saftey device so your pipe dont glow or worse. So think what you want that is all I was ever saying.
Nah . . . don't be a stranger Old Spark . . . everyone is entitled to their opinions . . . truth is what works for one person may not work for another . . . but it doesn't make that other person's method or opinion wrong . . . for example clearly Dennis is wrong in splitting wood vertically and insisting that it is the best method . . . but I still respect Dennis and look forward to reading his threads and opinions.
billc4 said:Update - so just the GM of the sweeping company was out with his tools. The only thing he could see was that the baffle on the top of the stove (the one with the secondary combustions tubes, which apparently moves) was forward about a 3/8" +/- from the back of the stove. This could have been letting the hot gases go straight up the flue. He slid it back by hand and said to see if that makes a difference. He also said that the flue as it comes out of the back of the stove should be horizontal or slightly sloped up mine is sloping down before it goes vertical. He said this could have also contributed to the overheating. He said flue was fine and was going to have the sweep come out to make sure the flue leaving the stove was horizontal or slightly elevated.
Sounds like all is well - any comments on the feedback I received from teh sweeping company?
Thanks again.
Bill
