So my few months old chain saw consistently drifts to the right. Both right and left teeth feel equally sharp, and look the same (to my untrained eye). I'll try to add a few pics:
Thanks! I'll flip the bar around. Follow-up question, since you said it needs dressing (even though the teeth feel sharp): Looking at sharpening kits, it's not clear to me whether they contain the right gauge for my chain. The chain listed is an 'ALP 50-57S', which I believe means it has 57 links (not important for sharpening) and has a 50 mil height difference between the cutting teeth and the depth gauges. This Oregon sharpening kit does NOT have the correct 0.050" depth gauge, right?Try flipping the bar. If it still drifts right it’s the chain. If it’s ok then it’s the bar. Need dressed.
Yes every s often you need to grind the bar that the chain runs on. One side of the chain guide could be wearing more than the other causing the chain to tip and a cut to drift. This is different than sharpening the cutters and filing the depth gauges.Thanks! I'll flip the bar around. Follow-up question, since you said it needs dressing (even though the teeth feel sharp): Looking at sharpening kits, it's not clear to me whether they contain the right gauge for my chain. The chain listed is an 'ALP 50-57S', which I believe means it has 57 links (not important for sharpening) and has a 50 mil height difference between the cutting teeth and the depth gauges. This Oregon sharpening kit does NOT have the correct 0.050" depth gauge, right?
I had thought about that. Even when I'm very conscious about not pushing down with the left hand, and try to apply a bit of torque in the other direction, it still drifts. I'm checking the chain tension often, and it's not on the loose side: when pulling up the bottom of the teeth is not quite coming above the bar level. I'll see how it behaves with the flipped bar. For now I'm waiting for new oil; just went through the first quart! Are all chainsaws quite generous with the oil? I feel like the oil dose could be reduced by a factor two, and it would still be plenty.Just a note might not by the saw or the chain but the operator . Do to handle locations it is easy to drift off . Think about it, one hand on back with trigger, other on top or left side. and generally standing off to one side a bit. Plus all of the above. Once it starts it almost impossible to correct short of starting over. If you are running the chain kinda loose it tends to pick its own path. note that a fresh chain install will always loosen up a bit so then you need to re-tension same after the first cut or partial cut.
Better too much than too little oil...Well, I have the kids' version (electric), so I don't really know how long a tank of gas lasts on these gizmos, but I'd say I need to refill every fifteen minutes of sawing. I'm guessing it's about 2 ounces (60 ml) every 15 minutes. Just checked the manual, it says re-oil every 10 minutes, so it is using as much oil as it is designed to. But should it?
Electric saw.Fill bar oil tank about every 1 to 1 1/2 tank of gas.
Make sure you mix 2 cycle oil into your gas or you engine will soon be seized and you'll be looking for a new saw.
Oh yeah duh i forgot. You just need a file that fits the size of your chain. Check your owners manual. or the box your chain came in if it's an extra chain. In the meantime i'd just get a new chain. Not sure about electric saw options but i've gotten very good aftermarket chains on ebay for my 18" stihl for around $15.Electric saw.
Ahh i don't agree with this really. Just get a sharp chain. Operating a saw with a crap dull nicked chain is just a bad habit and you will never know how to get great fast cuts. Dull chains wastes a ton of time and are hard on the saw.Depending on what you’re cutting, chains can dull quickly. It won’t help on electric, but I like to run the file every tank of gas, whether it needs it or not. It gives me a rest and I get to inspect the chain. Maybe every tank of bar oil would be a good gauge. More accidents happen when you push yourself.
If the cut is a little bit unsquare, the stove won’t care. Don’t stress out over this. If sharpening and flipping the bar doesn’t work, try cutting from the other side of the log.
Where did I say a sharp chain wasn’t important? I sharpen my chain every tank of gas! Where the tree grew makes a huge difference in how fast it dulls though. If you’re out in the woods you can get by without sharpening much longer than if you’re cutting roadside trees in suburbia.Ahh i don't agree with this really. Just get a sharp chain. Operating a saw with a crap dull nicked chain is just a bad habit and you will never know how to get great fast cuts. Dull chains wastes a ton of time and are hard on the saw.
A saw with a sharp chain is a fun saw.
A saw with a dull chain is not a fun saw.
