First off what a great site, wish i had found this before, might have saved me some time and trouble..
I installed a wood burning furnace in the garage and have had some trouble with it. Wondering if i am on the rright track or not..
Its a wood burning furnace with a blower that goes into some duct work for the garage. It has a 7" chimney outlet, which i reduced to 6" that goes into a through wall triple wall 6" pipe, than the only goes up 36". My whole chimney is only about 6'-7' long tops, from the back of the stove to the chimney cap. let me know if you need more info..
I was working with what i had last year, i suspect i shouldn't have reduced it at all, until I go into the 6" triple wall chimney?
At any rate what is happening is i get a good fire going with the bottom ash door open, i then ash shut the door (damper on the ash door doesn't work). After about five minutes the stove is huffing, pushing smoke in and out of the fire box door damper. the chimney damper is wide open, if i cut back the chimney damper it gets even worse.
If i don't watch it closely i get a garage full of smoke.. Please lay it on me don't hold back..
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
