New Quadra-Fire Grand Voyageur owner, here. It was installed, yesterday. Even though daytime temps are near 60 degrees here in CT, I had to try the new insert as soon as the installers left. ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I used a stick of "fat wood" between two logs, which I then covered with lots of good kindling, to get things going. Then I piled two more logs on top and things were burning well in no time. After an hour, I tried turning the airflow all the way down, but that resulted in a smoldering fire that required me opening the door for a minute to get my flames back. I guess I need a more established fire before messing with "slow burn" settings...
Anyway, here's my question: since I just wanted to burn one load (the installer actually told me to do that 3x to break things in), what's the best way to let the fire go out? I just gave the 3/4 burned logs a final poke, closed the door, and went to bed. I imagine they turned to coals and smoldered. This morning, my glass is a bit dirty looking, but it was clear when I went to bed.
I'm thinking the smoldering coals produced smoke that dirtied my glass? Would it have been better to tend to the coals by stoking them every now and then, or maybe cracking the door open so they burned-up quick?
Any other tips or tricks for my particular insert appreciated. I can already see that the ACC feature is going to take some experimentation, as is the airflow/burn rate control.
Thanks!
Don
Thanks!
Don
