rideau
Sending a PMWhat burn times do you get with the PH when it's opened up to heat. Also, do you run wot for you home?
I'm looking to upgrade my wood stove (cheapo us stove) with a real wood heating machine.
Thanks for any available help
How large wood stove before the kuuma?I heated the whole house with a stove in the basement. Put in a Kuuma furnace, Soooooooo much better, every rm the temp you want it and no fiddling. Almost instant heat when and where you want it. Don't have to wait for the basement to heat up before getting heat upstairs.
Dan, how often do you reload the Kuuma? Can you add your furnace model to your signature?
I have not made up my mind about the DHW. Not sure what $ it's worth? On the furnace side I'm mostly interested in the kuuma, it will heat water too. If the saving are there I'd do it.There are space heaters (stoves), and there is central heating (furnaces). With the size of the house under discussion, the line between the choices is a fine one here I think and you could end up going either way.
Myself, unless I was in something like the currently discussed house but without a basement, would want a central heating unit. I really can't comprehend how one could COMFORTABLY heat 3000 sq. ft with a stove - as mentioned was being done earlier. Not saying it's not done - but there must be a bit of compromise in the comfort of the far reaches of the house, some temp swings, and maybe even added details like fans to move the heat around.
As also suggested above, step 1 for me would be to get the basement walls insulated pronto. What counts in the long run, long after you do whatever, is your comfort. And maybe fuel consumption. IMO that will be attained best with a Kuuma - or similar. But, if you didn't want to take that plunge, perhaps the best next step after insulation would be to try a stove (scrounge Kijiji or Craigs for a good used one) & see how that works out with your new insulation. If it doesn't - you should be able to sell the stove for what you had in it & jump to the furnace.
For another angle - have you factored in possible heating of DHW? Some furnaces can do that.
Do you have a vaporfire100 or 200?That's a tough one. technically I put wood in 3 times a day. That is a result of my schedule, I do not fill full at night for I only want a 7 1/2 hr burn 75% fill. Morning 75% fill of larger softer wood for a 12 hr burn, Then after work 1/4 fill to hold be till night refill. This would be for a 20* day single digit night.
