If you can't get the new module to work I have a few extra's I bought in case I fried on on my bench. I will throw it in a envelope and send it out to you for free.Thanks. That part is unavailable anywhere anymore - I can only find documentation. Tuya does not have that product available for dev samples anymore. They are pushing their sandwich dev kits now. I was finally able to find the JWBR2S-5V mentioned in another earlier post. It should hopefully be very similar and I'll try it out and match up the pinouts between the two when they come in.
Thanks. Digging into it more, the pinouts should be the same, but the chip is different. The one you have is an ESP based chip, the one I ordered appears to be a WBR1 that Tuya developed and uses a different chip. The WBR1 isn't compatible with Tasmota. We'll see.If you can't get the new module to work I have a few extra's I bought in case I fried on on my bench. I will throw it in a envelope and send it out to you for free.
Got the new module in - Tuya JWBR2S-5V. Pinout is exactly the same as in the pictures above. IT WORKS!If you can't get the new module to work I have a few extra's I bought in case I fried on on my bench. I will throw it in a envelope and send it out to you for free.
I am seeing the same behavior.Got the new module in - Tuya JWBR2S-5V. Pinout is exactly the same as in the pictures above. IT WORKS!
For reference, the connector on the comfortbuilt board is a JST_XHP 2.54mm pitch - I just happened to have some. The connector on the Tyua is different, so I soldered directly.
There seems to be a bug in the programming though - not sure if it's just me or maybe it's the difference in the board. I have it set to Fahrenheit, the room temp shows up correctly (71*F), but the temp setting shows as 22*F. Modifying the temperature in the Tuya app actually does change the display to match, and it looks like it stops at 30, so I can't really see a way to make this work.
Also - it doesn't seem to shut off in temp mode. I had "wifi on", set it to 71 on the display, shows up at 22*F in the app, and it doesn't stop. I believe there really is some disconnect between Fahrenheit and Celsius in the coding of the stove.
Just me?
![[Hearth.com] Newbie - help.  WIFI possible for Comfortbilt pellet stove? [Hearth.com] Newbie - help.  WIFI possible for Comfortbilt pellet stove?](https://www.hearth.com/talk/data/attachments/304/304360-b7739b2d0316002817fc36667156dc91.jpg?hash=pmyYFvEZU2)
 ![[Hearth.com] Newbie - help.  WIFI possible for Comfortbilt pellet stove? [Hearth.com] Newbie - help.  WIFI possible for Comfortbilt pellet stove?](https://www.hearth.com/talk/data/attachments/304/304361-11879bf0394d5a9bc6ee1d66843e5bdc.jpg?hash=_xgeAfom6N)
Wow you’re pretty talented. I wish I had success. I’m using BroadLink remote but hate it never know what state the stove is in. Is there a way I could buy one of the wire set ups and a case from you?Thank you to everyone in this thread! I was able to successfully purchase and install the Tuya board. I removed the original connector and soldered on a standard PH2.0. I 3D printed a little case that let me mount the board to the rest of the control board assembly (photos and STLs attached).
I got it to connect properly with the Tuya app, but I really was not comfortable letting my stove connect to the internet. I tried this integration for Home Assistant called LocalTuya however it did not work. I figured out that it did not support the Tuya 3.4 protocol the board was using. I then tried this fork which worked however could not be configured to work fully with the stove. I created a fork here that will let you setup a climate entity, child lock switch, and alarm sensor (at least for low temp and ignition failure, which are the only 2 I found so far).
I'm pretty happy with this setup. I am able to control my stove from Home Assistant without having it connect to any cloud service. The only issue I've found is that I can't set the intensity in manual mode, however that seems to be a limitation with the stove and not the local implementation itself.
View attachment 304333 View attachment 304334
Yeah, that's no problem. I do have finals this week so I'm pretty short on time but shoot me a PM and I'm sure we can work something out.Wow you’re pretty talented. I wish I had success. I’m using BroadLink remote but hate it never know what state the stove is in. Is there a way I could buy one of the wire set ups and a case from you?
For what it's worth I ran into that today. I created an empty file and uploaded it.Hello,
I'm attempting to get the wifi module made on Tuya and it is asking for a firmware, and nothing is coming up under "associated firmware." Does anyone have a firmware file or any other suggestions to add wifi? I've read through the whole thread and I got as far as selecting the JWBRS-5V, but it won't let me buy now without a firmware. Thank you!
I love the stove and someone sent me a card which was super nice.I know this thread is more than a year old but looking into HP22N and remote access would be very important to me. Any movements on wifi module?
Just recently got the JWBR2S from Tuya and got it hooked up to my stove. I'm running into the same issue discussed earlier in the thread as far as the c° to f° conversion. Oh well, I use it in c° when I'm doing temp/eco mode. I can switch it to f° in manual mode. Works through the smart life app. Pretty easy install just note that the module is 4 pin pH and the board on the stove is 4 pin xh. I found a nifty cheap xh to ph cable on AliExpress that made my install even easier. Just make sure to rest the WiFi on the stove then start the pairing on the smart life app.I think they stop manufacturing the module. I cannot even find it on their website.
Anyone has an extra one left? Do we know if another WiFi module can be used?
Thank you!
Hp42 is the same model I recently hooked the Tuya wifi module up to. Their website is a nightmare to work with but I made a mock product as a WiFi pellet stove. When you order a sample board it comes pre flashed with the firmware. Unfortunately there seems to be no way to change the firmware on it to have different functions. I spent entirely to long trying to figure out different methods in trying to do so (including hooking the module directly up to my computer and attempting to use a debugging software to flash a new firmware on to it). I resulted with just sticking with the standard firmware that came with the module. Only downside is the whole C° not being able to properly switch/convert to F°. I can turn the stove on and off remotely and adjust the temp in c° when using the remote function. The occasional Google F° to C° to do my own conversion and inconvenience is made slightly less inconvenient.Hello, just got a Comfortbilt with the empty wifi slot. Looks like this is hard to find now. Im in Mammoth Lakes as well. I have the HP42 and love it so far. the wifi module would make it perfect.
