Hi, I'm new to the forums and pellet stoves but regarding electronics I'm a jack of all trades and a master of none.Hello All - Newbie here. Love my Comfortbilt pellet stove. But I'm in need of a way to utilize wifi to remote control - wifi t-stat? I drivve at least an hour each way to work - would like to use a wifi app to start my stove when leaving work.... is this possible?
Wi-Fi module introduction--TYJW2S-5V-Documentation-Tuya Developer1.Product OverviewTYJW2S-5V is a Wi-Fi module with 5V TTL UART series port ......
Where did you find the module? I've been looking for one...Follow up from my prior post. I tried it and it worked great.
1. Had to slice my connector to the mainboard because the plug was a different size.
2. Followed the Tuya/Sonoff/Wifi procedures to connect it to my wireless. (I tried a few different methods but the Tuya Smart app finally found it and labeled it "basement dehumidifier."
3. Verified that I was able to control the pellet stove so I renamed it pellet stove.
4. left home and verified control of my stove from out of my network.
5. Made an Old Fashioned and relaxed.
I may hot glue the Tuya module inside the case but I taped it to the back so I could troubleshoot without taking the case apart again if I needed to....I didn't. It worked right the first time.
View attachment 287133 View attachment 287134 View attachment 287135 View attachment 287136 View attachment 287137 View attachment 287138 View attachment 287139
I bought it on Ebay. I just looked and don't see one now. I'll keep looking on ebay because I think they don't make it anymore.Where did you find the module? I've been looking for one...
Thanks, You're awesome. I looked at the one you ordered and also found this, TYJW2S-5V-BL Wi-Fi Module, which looks like more of an exact match to what I have. I don't know enough to know the difference but figured it's worth mentioning. It's $3.70.I ordered them direct from the manufacturer for $4.08 each. Since they where so cheap I got 5 just in case I hosed a few up. Shipping was 5 days from China. When you get the module connected make sure to do a WIFI reset via the stove LCD config panel or initialization of the module will not take place and will be undiscoverable during the provisioning phase when adding the device to the Tuya app.
Create an account here: https://auth.tuya.com
Once you are logged in look on the left hand side of the menu and click Overview > Sample Store and search for "JWBR2S-5V Wi-Fi&BLE Dual Mode Converter" add a few to your cart and complete the checkout (an adventure in itself).
The site is extremely hard to navigate and take a bit of patience.
I'm having a real tough time ordering the pieces from them. When I try to submit any order for either of the parts I get an error message saying "The product firmware has not been released and production orders cannot be placed." Any advice?I ordered them direct from the manufacturer for $4.08 each. Since they where so cheap I got 5 just in case I hosed a few up. Shipping was 5 days from China. When you get the module connected make sure to do a WIFI reset via the stove LCD config panel or initialization of the module will not take place and will be undiscoverable during the provisioning phase when adding the device to the Tuya app.
can you tell me what thermostats are able to hook up directly to the HP 22n I talked to comfort built and they said that this unit is compatible but I don't know which ones would workIf your stove has the option of connecting an external wired thermostat (normally open contacts), then you can use any WiFi thermostat (Nest, Ecobee, Honeywell....) to control your stove remotely.
how did you get the wire for the Wi-FiI'm having a real tough time ordering the pieces from them. When I try to submit any order for either of the parts I get an error message saying "The product firmware has not been released and production orders cannot be placed." Any advice?
I also have a D1 Mini from another project I plan on connecting to see what happens and 2 TYWE3s chips I may try to solder and replace the TYWE2S chip and see if that makes any difference.
I can control mine just fine but feel irrationally compelled to find a solution with easier to find parts. After that I'd sure like to figure out how to change the language to English.
Either way, I'll be back at my place with the stove in 2 weeks and will see what else may work.![]()
I got the Wi-Fi chips today but I was told by comfort built that the data cable that goes to the display is the same as the one that goes to the Wi-Fi chip but the display plug is slightly bigger than the plug on the Wi-Fi chip how do I get a smaller plugGood news, I think I figured out how to order from them after chatting with support.
You first need to create a product, associate the hardware and then order it for testing:
- Go to Product, then Development and then Create
- I selected Small Home Appliance and then Heater
- Then you go to Hardware Development and Select Hardware
- I selected the 5V TYJW2S and then you can do Buy Now and it lands in your cart
- From there you can check out without error
Hope this helps.
If your schedule is simple you may want to utilize the weekly schedule options in the stove menu under General Settings. That information is in the manual.
That said, I too am looking to enable wifi on my Comfortbilt HP22N stove for my place in Mammoth Lakes which is a 5-6 hour drive every Friday evening. I'd like the place warmed up when the wife and kids enter.
I took the control box apart and see there is a 4 pin connector labeled WIFI and a breakout spot right behind it for easy access which I'm going to try to use. In the U.S. I believe manufacturers are not allowed to enable it as per EPA something something global warming blah, blah, blah. I've purchased a Tuya WIFI module TYJW2S-5V-BL and will try hooking it up this weekend.
1.Product OverviewTYJW2S-5V is a Wi-Fi module with 5V TTL UART series port ......developer.tuya.com
My assumption is that I'll be able to follow the standard Tuya procedures for connecting it to my wifi and then use my app of choice to control it. The circuit board does not appear proprietary.
The next part will be enabling remote access. While the app may solve this if it's cloud based I'll probably either try to use my Hubitat home control device to interact with it or I'll set up a Raspberry pi zero to run a server I can log into via a browser.
I'll keep you updated but it is likely to be a long process because I'm only up there on weekends and skiing/snowboarding/snowmobiling/snowkiting take priority.
I have the wifi chip and the wire connectors how do I know what wire goes where? they are the same colors but how do I know what ones are power and transmission
Don't have my stove installed so can't test yet. My first guess would be for the pinout to be the same as on the wifi board. If no-one here posts it by the time I need to install it, I will take a multimeter and search for the ground and +5v pair. After that its a 50% chance to get RX and TX right.....I have the wifi chip and the wire connectors how do I know what wire goes where? they are the same colors but how do I know what ones are power and transmission
