It is a single wall stove pipe. But the required clearances on this stove are weird...actually larger for double-walled than single walled chimney pipe. Sounds impossible, but apparently it has to do with the stove firing hotter with double walled pipe. There is one thread about this weird situation on this website. Anyhow, clearance from the stovepipe to the wall is listed as 13 with single pipe...but then in the diagram it is listed as 18 inches. With double walled pipe it is 15.5 inches....anyhow, I will just play it on the safe side and assume that 18 inch is the correct number. Seems pretty standard for stoves anyhow...Are you using single-wall or double wall stovepipe? You mentioned it's an existing masonry chimney but you may want to double-check clearances since single-wall has much larger clearance requirements than double-wall.
Didn't catch the guys name...if it is incorrect afterall, I will maintain the 18 inches. I do have a shield on the back of the unit itself, but that has come standard on this wood stove for years apparently.That is bad information. Did you get the tech's name?
Yes, you will want to replace it.Hey guys...hope all your stoves are cranked up. Pretty chilly here in the northeast...happy to say my Englander has performed well this season! Had a quick question about the fiber board that is on the top of the interior of the stove, above the perforated steel rods (which I am assuming is the exhaust for the unit)....anyhow, I noticed that there is a slight hole in the mineral board (about 3 by 3 inches). I am not sure if I punctured the board or if it came like that from the guy I bought it...anyhow, I am wondering if this is something which is hindering performance and if it is something I should change. Apparently in the manual it does state that taking this board out is possible and recommended for cleaning the unit...so replacing the fiberboard is not the worst thing. Any thoughts?
My stove is very different so I can't speak to the hows but others here can. There have been threads here in replacing Englander boards for the nc30 that were aftermarket and they seemed to work fine. It wouldn't hurt to check the chimney to see what build up you may have and how to fix it.Okay, any good source for this fiber board online/locally? I am in the catskills...northern poconos/scranton also okay.
The chimney liner is new...installed it myself in October...think I should still clean it?
