Hi Grovenburg
My setup is boiler and storage in it's own building 120' from house.
Foamed in trench lines
In the boiler building i have my Backup Oil boiler.
I have the wood boiler and storage one one side of a plate HX with water,the oil boiler and underground lines on the other,these have glycol in them,so far i have less than a barrel of glycol in my system.
I went this setup for a few reason.
-wife and daughter have Asthma
- no flame source in house
-no mess in house
-no worries of freezing lines,the wood boiler and storage is protected by the Oil boiler and a circ that comes on if the temp drops below 50 in the Econoburn
My boiler building gets very warm after a long burn,anything more than two loads you need to be in a tshirt to work in there,no insulation on lines in building,works well to dry wood though.
In the future i will try to retain the BTU's in the system by insulating the copper lines in the boiler building,and this building will eventually be tie in with my shop,so extra heat will be used in the shop.
The con's are more wood usage,a walk in the winter weather to tend boiler.
I'm glad i found this site prior to starting,otherwise i would have crappy lines and a bunch of other problems.wish i would have had a couple of years to plan after i found this site,but it's built now.Tweeking for a few years to come.
Read as much as you can before you begin,and post any Questions you have.Redesign is the easiest before you begin to solder.
Good Luck
Thomas
