New wood stove install (help the noob)
keep in mind that the "cheaper" stoves often require greater clearances to combustables than the better built ones. plan the entire installation before purchasing a stove. You can often find great stoves used for a decent price. The epa rated ones are typically the way to go. Another option is to take the zc box out and install an epa fireplace, (wood stove in a zc box) Kozy heat has a great one called the Z-42, Bis also makes some great quality units. Prob. looking at around $2500 plus chim for that option, but don't have to take space out of the living room or cut a new hole in the ceiling. Just some options.
I found this one but even this is a tad too big to fit inside the prefab I have here. This would be really nice if it would fit.
(broken link removed to http://www.countryflame.com/model02.php)
How about this guy?
(broken link removed)
looks like it should fit. The measurements I got from the prefab are
18 ½ wide in rear
28 ½ wide at opening
18 ¼ high at opening
16 ¼ deep
