I have just recently purchased a regency 1200i for my fireplace. It was the largest stove I could purchase for my prefabricated fireplace. I have had a few fires going in the stove but I am not sure about how to use the draft to obtain maximum heat output. If I move lever all the way to the left I see yellow flames If I set it back I start to see the blue flames dancing around and I was under the impression that blue flames are better and Hotter than yellow which is correct?. Non insert stove users recomend a thermometer to tell what is going on in the stove what should a insert user use? I also have a question about my install. If I have a stainless liner from stove to cap but No blockoff plate is this ok? Will I be losing heat that should be going into my room and instead rising up the chimney? if heat is rising on the exterior of my new stainless liner where the original fireplace stainless liner is but cant escape can that build up of heat cause problems if it cant escape?
Thank you.
Thank you.
