I have at least an infrared now, I don't believe the magnetic have arrived.This is difficult to determine. It's unknown how much ammonium phosphate was released and how much is remaining as a coating. That said, if you lose power for an extended period of time and have no heat, then the wood stove may be the only option. The system will be safe in the short term. It's longer-term corrosion that is the concern.
Did the thermometers arrive? They should help you burn more confidently.
But aside from any differences in burning due to leftover residue, I can confidently run a small fire for heat in the stove at this point. The only issue I had was on reload and I learned a lot from that as well. My primary concern would be safe operation and secondly my concern would be long term corrosion. I can always sweep the chimney next week instead. I don't really know what effects on fire the residue would have nor on the fumes released as I believe it breaks down around 500 degrees into ammonia.
The temp here is only going to get down to about 25 degrees, so I can live without the heat. I'd rather sit inside under a blanket than sit outside in the ice while I try to figure out how to remove toxic fumes from my house. But - if it's safe I'd like to run it. I don't like the cold. It's why I bought the stove.
