Hi Everyone,
New to pellet stoves.
I'm having a problem with my New Breckwell Big E.
I bought it online,I know I Know flame me now (good got that out of the way) so no dealer support.
It's not heating the way it should be from what I read here. Here's whats happening.
The unit starts up fine after the initial fill of the burn pot (filled about half way) nice flames 6-10in high but it almost burns itself out before the next feed, flames 1-2in high.I advanced the feed rate to the highest setting still with the same results. Its the same on all heat levels 1-4 I did not try #5. While its running I used the feed advance and the flames went back to 6-10in and it started to throw more heat.
The unit is on manual not on/off or HI/low,the damper is in all the way,I checked for auger jams checked for leaks, still nothing changed after I resealed the pipes, fixed air leak on door gasket (failed dollar bill test) .
It seems to be a feed problem,but its feeding like the chart in manual says it should be (times and duration of feed).
I need help, any ideas would be greatly appreciated,Thanks
