New to me Jotul F600
Brolley
25
Center Valley, Pa
Hi Woodies! Got a used Jotul F600 today for $700. Probably should have done some more research but its mine now and I will hopefully get it up and burning. Stove looks to be in decent shape... its missing the door glasses, smoke outlet,handles and I think an upper baffle and insulating blanket. From what I could find on the web its supposed to have a baffle that sits on top of the burner tubes and a blanket on top of that. Also the pieces that the tubes connect to,dont know what they're called, are damaged on one side.
Just getting started so feel free to correct me in any way. This seems like the right place to be.
1st pic is the damaged piece where the burner tube goes.
2nd pic is some pieces I found in the ashpan??? What did this used to be?
  • [Hearth.com] New to me Jotul F600
Welcome to the forum Brolley. I'm green as grass myself but this is a very friendly and helpful place. Sorry to be no help with your issues.
Looks a bit rough. What I see you need to replace the secondary air manifolds and tubes as well.
Look a bit rough. What I see you need to replace the secondary air manifolds and tubes as well.
Yes, the manifold on one side is shot. The tubes look to be in good shape though. Any idea what those pieces in the 2nd pic are. They kinda look like honeycomb. Could they be pieces of the old blanket?
I don't have the stove, so only guessing. Maybe a bee nest, rope gasket, insulation blanket.
