Its been a long drawn out ordeal for me to get to this point, but I feel compelled to write this thread and give a big thanks to this forum and all that contribute to it. A little background, 2007 we were in the building stages of our current home and I was completely engulfed with the construction project. One thing I was sure of though, after years of having an add on furnace in the basement in our first house I was done with having a fire in the house. I was going to have an owb to heat the house, garage, and dhw. And I did, and 10 years later I do. It is still heating the house, garage, and dhw. I never will forget how excited I was that day I started the first fire in it and then how I stood there in disappointment as I watched how much wood it consumed to get itself up to temperature. It was at that point, that first day I knew I had probably made a mistake. But, you sleep in the bed you make and I have tried to make the best of it. In all fairness it has done exactly what it was advertised to do,and saved me a ton of money in fossil fuel costs. I typically load it up twice a day from wood that I cut and process myself and it keeps us warm.
In the meantime, I had came across this site quite a while ago. At first I was completely blown away with some of the complexities and set ups some guys have. Then after a while I started to grasp some of the concepts and what was really going on, and where I wanted to be. I knew I had all the right parts already installed inside the house and thermopex in the ground, so for the last 5 years I have been slowly accumulating the components I need to make the switch. I found a lightly used EKO 60 for a pretty good price, I was able to find both a 1000 gallon and 120 gallon propane tanks at a local scrap yard and convert them to storage and expansion. I had built a woodshed next to my owb and have been slowly converting half of it into a boiler and storage room. I moved my thermopex over into the room and just ran a temporary lineset from it to the owb,
At this point I have the EKO plumbed with 1.5" to the storage in a 2 pipe configuration but not tied to the thermopex. For now I have the storage wraped with fiberglass and the boiler room pretty well buttoned up. I have not disconnected my owb, it is still my heat source as I have been slowly testing my new to me system. I have been learning as I go building small fires and sending the heat to storage. The heat this thing puts out in full tilt is impressive. As close as I am, I am still not ready to cut the cord just yet. I have some small pesky drips that I need to get sealed up and I want to have the storage tank sprayed with closed cell this spring. I still need to decide on what temp probes for the storage, and I have a little more insulating to do in the boiler room. I will try to post a few pics as I can but things are still a mess as I pick away with this project. Thanks again to everyone who contributes to this forum, I wouldn't be to this point without it. More to come...........and if anybody is in the market for a good used owb..............
I do mind doing it, I just wish I had more time. When you retire and have time, your body may not be up to it. So it goes I guess...
