Melissa220,
Fans can help or hurt, the goal should be to get the hot air moving up high by moving the cold air (relatively cold) towards the stove down low, this gets the cold air to the stoves convection air intake so it can be heated, and the warm air distributed away from the stove room. It is a balancing act and how far away from the stove you can get heated will depend upon this convection loop and how well your house holds heat (note insulation and lack of air infiltration helps tremendously).
I do the heating from my den in the basement without any fans other than the convection fan on the stove.
Harmon Lover 007,
Sorry, I couldn't resist. I'm a bad Bear at times. Now about that feelings issue you seem to have, a nice large steak on the grill along with your favorite beverage will take care of it.
Bout time you admitted that!![]()
Look who is flapping his gums.
Have you enough in your stash to keep your pig status or do the hogs need hold an eviction meeting?
I think what i'm doing is worrying about a problem that I don't even know if I have! Note to self: STOP WORRYING!![]()
That is a good question jtakeman! I know the dealer I bought the stove from carries pellets and they gave me 8 bags of Okanagan to start. I have no intention of purchasing from Walmart, Lowes etc. So I will need a reliable source with a mid-range priced good pellet. One with not much sawdust,etc.
Yep! Sitting on 3 1/2 tons!
I'd be worried more about what pellets your gonna stash before all the other hogs/pigs/oinkers snarf em up on ya! Specially that fella I quoted above, He hords them by the trailer load!!
Another welcome to the forum and all the strange critters that scurry about round here.
Stove looks great and with all the humidity lately, at least the burn in will dry out the house....and crank up the temp too
Your dealer did you a solid by starting you with Okies, but that may just spoil ya and get you hooked on the good stuff ! !
Dont rule out Wally World and Lowes so quickly. They do get some good mid range pellets for decent pricing at times. Last year I found Walmart having MWP at 199/ton and 2 years ago, Lowes had Somersets. Both are quality pellets. You just have to be on the lookout. Lowes will have Green Teame quite a bit, but lately they have been overpricing them.
You will learn all this by trial and error though, if you are so inclined. Most of us here will try many different brands in small amounts first, and that is recommended. Overall, your stove will burn almost anything.
Keep it clean and it will keep you warm and toasty !
Welcome Melissa,
In reading this thread, there seems to be one warning that has yet to be mentioned. Many of us have become OCD since buying a pellet stove. Speaking for myself only, when I stack pellets, the bags all have to be face up and be facing the same way. The stack must be straight. When the stove is running and I walk by, I have to open the hopper and check how many pellets are left, even if I filled it 5 minutes ago. Now that I have the hopper open, I have to smooth out the pellets, etc, etc. It's contagious, so be forewarned.
We call that pellet fondling, been discussed before and many here have the disorder.OMG -i smoothed out the pellets!
Well, it operated for only 90 minutes yesterday and I have already checked to see how many pellets it consumed and - OMG -i smoothed out the pellets! I need help already and its only been in the house less than 36 hours. I have even scraped down the burn pot! Is there therapy for this??![]()
So the listing in your signature, for example, means that you have that many bags of pellets on hand? Seems like i'll have to go pellet shopping this weekend and get a few bags of several different kinds to try. Seems like the thing to do is stock up beforehand. Look out all you pellet pigs.....I'm on the prowl!
....Isn't this how OMV started?!?!!Melissa, you Pellet-fondler, you!So the listing in your signature, for example, means that you have that many bags of pellets on hand? Seems like i'll have to go pellet shopping this weekend and get a few bags of several different kinds to try. Seems like the thing to do is stock up beforehand. Look out all you pellet pigs.....I'm on the prowl!
LOL. Didn't take me long!
I am discovering a little knowledge can be dangerous. In reading other threads, I noticed talk about the draft voltage and adjusting it for different pellets. I did not notice my installers checking the draft before the first burn to cure. In everyone's opinion, is this adjustment something I need to consider going forward?
Mel:
ANY and ALL installations should have the draft checked and adjusted.......I'lll say it again.....ANY and ALL. If nothing else, it gives you a clean stove- base reading to compare to if you have issues at a later date......the procedure is in your manual, on page, oh, about, 20, or so. The draft isnt adjusted for different pellets.....feed rate maybe, but not the draft. The draft is a function of your line voltage, combustion fan, and piping setup, as well as the cleanliness of your stove. Should be checked.
Hang around here for a while, you'll learn not to do that.I assumed they knew/know what they are doing.
Hang around here for a while, you'll learn not to do that.![]()
j/k
) myself included). But reading, searching, and askings questions will put you far ahead of the average 1st yr pellet burner..
