I am probably the worst kind of wood stove owner, I have one that was in my house when I bought it a little less than two years ago. While not completely unfamiliar with wood stoves prior to buying this house, I certainly know a lot more about stoves after reading through the posts on this forum!
I am having a problem I need help with but first a few pertinent facts.
Starting about a month ago I started to have trouble getting fires started. I was doing everything exactly as I had done before but it was just taking longer, sometimes even requiring multiple attempts which was odd. At first the fire would eventually get going as before and burn hot enough to maintain itself and I could shut the damper so the secondary chamber would operate, but before long that was no longer possible, shutting the damper would shut off the fire. Then I found I was having to leave the stove door cracked open to maintain any burn at all, and now I really can’t even get a fire lit without considerable difficulty so I have quit using it until I figure out what is going on.
My first thought was obviously a blockage in the chimney, unlikely to be soot/creosote since I had less than a year’s light use since the last cleaning but I thought maybe a critter nest or something. I can fit my phone camera in through the damper and look up, no blockage up to the one bend in the stove pipe. I went on the roof, took off the cap and looked down, no blockage there either (and very little soot buildup). The one piece of pipe I can’t see – the bend- is only maybe a foot or so and I think very unlikely to be blocked, plus I am getting no smoke in the house or backdrafts. The damper and airflow throttle appear to be fine, and I have kept the ash collection pan reasonably cleaned out. I think this stove has a catalytic converter (how do I tell?), but I don’t believe that activates until the damper is shut (correct me if I’m wrong) so I don’t see how that could be keeping me from lighting a fire? At any rate, while I readily acknowledge my lack of experience with stoves I am just stumped, there just aren’t that many moving parts here and nothing else has changed, no new ventilation fans in the house or anything like that and I'm using the same firewood. I always crack a window when I light it to make sure I’m drafting in the right direction, and I can definitely feel the air moving up the chimney before I light the kindling. And again, I am not doing anything differently then when I first started using it and it worked great, including the first part of this season.
I’ve got a stove guy coming out to look at it in a couple of weeks, but was wondering if anyone here has any ideas? After reading more threads here I am guessing I need some kind of stove repair/parts replacement, or a rebuild?. Given the apparently mixed rep of the stove and expensive parts I assume it might be best to just replace it, but it would be nice to be able to at least use it through this winter (or longer) and hope that supply chain issues get better over the next year. I’m not sure there is much to choose from at present. And it is supplemental heat. Thanks!
- The stove is a Vermont Castings Encore 2550. I'm not sure how old it is but the mfg date code on the back is 1219 (121st day of 2009 maybe?) I can see reading through some old threads here that maybe this was not a great stove to begin with but it appears to be in good condition and passed an inspection (with chimney cleaning) that the seller provided prior to my buying the house. the house was vacant for about 2 years prior to our buying it.
- The stove is not our only heat source, we just use it in the great room for a little extra warmth on cold nights and ambiance.
- The house also came with several cords of cut firewood - while it is only pine (we live in the Pacific Northwest!) it is quite dry and burns very well. I'm burng the same wood this year that I did last year.
- I did not attempt to use the stove for some time after we moved in, first because it was spring and then because I was just too busy with other things involved with having moved during a pandemic (not recommended btw!). I finally started using this stove almost a year ago and then starting again this Fall when it started to get cold again - but in both years mostly just weekend evenings unless its really cold out.
