I’m running a Napoleon s25i. Install and inspection was in late December. I’ve been pretty much using it daily. Every single time the Rutland thermometer gets in the middle of the green burn zone I’m getting an eye-watering smell. I did find some paint had bubbled and flaked off on the sheet metal on top that brings air into the blower. I’ve removed that piece-with a replacement coming-along with every bit of paint flakes i could find and still the stink continues.
The store i bought it from contacted Napoleon and they’re blaming the paint issue on the part that’s no longer there….
The fireplace bricks were painted white prior to me purchasing the house. When the stoves cold and i remove the backer plate i do see that some of the white bricks covered by the backer plate appear singed-an almost toasted marshmallow color.
Could this white paint-which is probably house paint in some form-be causing the smell?
I’m running a Forever Flex insulated liner through an aluminum block off plate with Roxul on top of the plate and around the liner where it passes through.
Thoughts ? Paint the white bricks with high heat paint??
