New liner in and ... wow what a difference!
Jimbob said:
The fact that you get good secondaries, and that you can easily "bury the needle" on the stovepipe thermo, tells me that you already have good draft.
You have a 7" insulated steel chimney, running straight up through the ceiling?
In your situation, a damper might help you.
It'd be worth a try, anyway.
Yes Pen said that also and I guess it is well worth the try, now that it is warmer I could do it, the chimney has two ninety's, one in stove pipe and the thimble with an over all height of about 18 ft.
Actually, your chimney set-up sounds like what my FIL has. He installed a damper on his, and he noticed an improvement.
His isn't a Summit, it's one of these:
http://www.flame-intl.com/product.aspx?CategoId=1&Id=394
But it's still a non-cat, EPA stove.
Keep us posted on how it works. For the $7 or so, it's worth a try.
