Hey Guys, Finally got my VF100 is installed and up and running. Got the first fire going in it this morning. Had a new stainless steel 30ft liner put in and raised my thimble up from 3ft for my old stove to 6ft for the VF. The draft is strong, but the barometric damper is keeping it in check. We ran some 8x24 rectangular ducts from the VF to my central units plenum. House is 4000sqft, average insulation at best,
I can’t believe how well it works. House was pretty cold this morning, around 65. Fired up the VF and turned it to high and it was 74 in here in no time. That’s when I decided I needed to turn it down to low lol. I’ve been going around the house and feeling the registers and the air is very hot. The VF in the basement and there’s two floors above it and the blower seems to really distribute the air well, even to the rooms furthest away.
The way this thing controls the burn is crazy. I filled it up about 3/4 full with red oak 6 hours ago, and I stlll have full logs left, though they are coaled. With my old stove by now at best I’d have a pile of hot coals, but no distinct log shapes left. At this rate idk if Its going to be ready for the overnight load in 2-3 hours. It seems like I could probably get away with 2x a day loading, but will see as I use it more,
It also keeps the basement warm. I wasn’t sure if it was going to be able to due to the layout. The VF is in 1 of 5 rooms down here and 4 of them are comfortable. The 5th, my workshop has never been warm since it’s so far away.
Only thing I’m going to probably change is the location of the low limit switch. The blower is going on and off. But I’m not even sure if that’s a bad thing, since it helps not overheat the house. If I Move the low limit up the plenum will the blower constantly run?
All in all I’m really happy so far. We’re supposed to be getting some cold weather this week, so I’m excited to put it to the test. My only complaint is having to cut my wood down from 24-26 inches to 20. But since it’s so late in the season I only have about 2.5 cord left instead of 7. I appreciate you guys suggesting getting the Vf now and skipping the used old school furnace.
![New Kuuma VF100 Install New Kuuma VF100 Install](https://www.hearth.com/talk/data/attachments/292/292146-581a2ccb49a9c47f71a5475fc549faba.jpg)
![New Kuuma VF100 Install New Kuuma VF100 Install](https://www.hearth.com/talk/data/attachments/292/292144-3b1714a13a3ffc06537022fce0925b63.jpg)
![New Kuuma VF100 Install New Kuuma VF100 Install](https://www.hearth.com/talk/data/attachments/292/292145-4e73733320d7e5bf8572ae23b5efd258.jpg)
