JRHAWK9
I might be wrong here but on the kumma Isn’t the high temperature probe that is mounted in the plenum 250*?
nothing wrong with the dump opening before that high limit.
My Yukon EHD came with the 210* link...and believe me, that monster ran higher duct temps than any Kuuma! (had to run 'er hot to keep the chimney from plugging up in less than 48 hoursnothing wrong with the dump opening before that high limit.
My Yukon EHD came with the 210* link...and believe me, that monster ran higher duct temps than any Kuuma! (had to run 'er hot to keep the chimney from plugging up in less than 48 hours![]()
No its in the EHD...which gets attached to the side of the plenum after a 12" ish hole is cut in the plenumWhere is the fusible link installed? Inside the plenum?
Looks like the next one down is 165*I was going to mention we could get a way with a MUCH lower fusible link temp.
Any others that would be interested in an emergency heat dump? Considering making a few...
No, there is nobody left in the forced air wood furnace world that gives a rip about a EHD...they all just tell you not to install in a down-flow configuration, etc, etc...but I hear ya...liability/headache/hassle would be the main reason I don't do it, if I don't.There’s a reason that the big boys with insurance and lawyers won’t build these things.
I mean is it installed on the inner side? So that it's in the heated air stream?No its in the EHD...which gets attached to the side of the plenum after a 12" ish hole is cut in the plenum
YesI mean is it installed on the inner side? So that it's in the heated air stream?
If free labor equates to a free heat dump count me in for sure. I could probably run up there one weekend and help you if you want.I thought you were working from home?!![]()
Not yet...wanted to see how much interest there actually is first...have some ideas in mind for design...probably 12" x 12" (tall/wide) x 8" ish deep.
As far as the link, I was planning on the same one that came on my Yukon EHD https://www.mcmaster.com/1147A19/
You sure you wanna expose yourself to that liability...we might get our pants sued off...If free labor equates to a free heat dump count me in for sure. I could probably run up there one weekend and help you if you want.
That you could make of parts you can buy today. A normal (large) register on the floor above, with an upward duct controlled by a normally open electric duct damper. Power goes off, damper opens.It may not be pretty, but a dedicated opening close to the plenum within the living space feom the main trunk would be ideal. Power goes, trap opens into floor above and gravity takes hold. Our previous furnace during an outage would get so hot, water droplets would dance on the surface of the ductwork above it. Nothing that I would ever wish on anyone! But 6 cubic feet of firebox burning white hot during an outage was a fire waiting to happen.
Did you ever find anything out about a emergency heat dump?You sure you wanna expose yourself to that liability...we might get our pants sued off...![]()
Haven't forgot about it, haven't done anything with it though either...Did you ever find anything out about a emergency heat dump?
These are not boilers, they are forced hot air furnaces fired by wood...and computer controlled, so they pretty much can't make creosote, so very safe...safer than most manually run stoves IMO.This is a off the wall question? How much would a 1000 gallons of oil be in contrast to about 6 cords of oak wood? These boilers work on wood and I am just curious about the pricing and would not oil be easier to use instead of having to load this thing up once a day which by the way is "great" compared to some of the other wood appliances...I read some of this thread and I got very concerned about the safety of these things knowing not much about them..and just wanted to compare these two prices to really see what we are talking about..clancey
