I finally retired my trusty VC Encore 2190 that I purchased in 1994 and plan to install it in the barn after I rebuild it.
My new Jotul was installed a couple weeks ago. Installation was painless since I took careful measurements and ordered the short leg kit with the stove. Everything mated up perfectly.
I completed the break in fires per the manual. I've now burned three normal fires. These are the results:
Fire One:
Stove puts out WAY more heat than my old VC. I'm stunned at how much more radiant heat comes out the front glass. Uncomfortably hot. My hounds used to lay in front of the VC all night. Now they jump up panting within thirty minutes and head to the back of the house. Stove top temperature is 575 degrees. Stove pipe is 550 degrees. Cat temp is 1400 degrees. I can't calm the fire down even on the lowest primary setting. Burns wood like it's free. I make sure that all doors are closed properly (especially the ash pan door) Wife complains that it's too hot in the kitchen. It's 41 degrees, cloudy and windy outside. Temperature hits 74 degrees in the living room. It never went over 68 degrees in the living room with the VC during similar conditions. I turn every fan in the house on to try to distribute the heat in our 2100 sq/ft house. End up opening an outside door to cool off.
Fire Two:
Same as fire one. Holy Smokes this thing gets hot
Wondering if I have enough wood. I cut, split and stacked enough wood for about five years last winter. Wondering how long it'll last with this monster. Questioning my decision. Stayed up darn near all night reading everything I can find on Hearth.com and elsewhere to try to figure out what's going on. Watched many YouTube videos. Found nothing conclusive..
Fire Three:
Before starting the fire I cleaned everything really well looking for problems. While cleaning out the ash pan area
I notice two 1/4 inch holes in each side of what the manual calls the Ash House Assembly. One on the left side and one on the right side. I shine a flashlight through the holes. Yep, they go all the way through. I start the fire and when it's once again burning hotter than the fires of Hell I put a magnet over each hole to cut off the air flow. Well, what do you know. The stove top is now sitting at 450 degrees. The stove pipe is 425 degrees. The Cat temp is now 1100 degrees. The cat is glowing a dull red instead of almost white hot. The fire is burning lazily just like my old VC and the stove isn't eating wood like it's candy.
Any thoughts you folks have on this would be greatly appreciated.
View attachment 288309View attachment 288310
