corrugated metal is a real pita to flash correctlyCorrugated. I'm using duratech chimney pipe. I figure all the dsa flashing works about the same. I guess I should just use duratech flashing. It will probably fit my pipe better.
A shallow stove that is wider than deep. E/W means the wood has to be loaded parallel with the front door. N/S means wood loaded parallel with the stove sides. These are typically deeper stoves with the advantage that the logs don't roll up against the glass.Whats an E/W loader?
I bought one last year, and sure can't complain.Ok thanks I was just wondering. I'm installing an Englander 17-VL. It sure is tiny but has good reviews and I have a very small house..
I have a question about the 17-VL. The fire brick in the top of the stove does not completely cover the top of the fire box. Should it be towards the front, back, or in the center above the secondary burn tubes?
