Need to add that when the Ranco calls for heat, it turns "on" both the radiant circ and the circ that supplies the system side of the HX.
j said:Thank you Jebatty,DBB,and EW it seems as though you are all on the same page which makes me feel good about proceding. A couple of quick comments, I dont think my shop needs to be as warm as yours Jebatty ,so at what point do you hinder the performance of infloor. In a perfect setup for me the infloor would stay set at the minimum temp required for thermal mass consistency without sending super low return temps back to the boiler via termovar. Is 50 degrees too low? What about a Timer set to pump to the shop for 3 hours in the late afternoon when my storage is depleted anyway?
DBB, Due to having the glycol I was going to use a hydronic unit heater and not use any gas burning appliance. As I stated with Jebatty then I could just boost the heat up with the unit heater if I am home and there is a fire burning.
My system is heating the shop ,but also a 2200 square foot home and DHW for 4 (2 teenagers). I do have 1140 gallons of presurized storage and have been only making one fire per 24 hours, I understand that may change with the shop now but at the 24 hour mark I usually have about 1140 gallons with a temp of 160 on top to 130 on bottom so there is useable BTUs to send to the shop.
# ID# DATE TIME TEMP SENSOR
521,0000027B7420,"12/3/2010 8:10:06 AM",72.275,BIN
521,00000220F620,"12/3/2010 8:10:06 AM",105.8,L2
521,0000025BBED8,"12/3/2010 8:10:06 AM",102.2,BOUT
521,00000220D3F8,"12/3/2010 8:10:06 AM",106.025,R3
521,0000027B8B34,"12/3/2010 8:10:06 AM",99.5,AOUT
521,0000021E05CC,"12/3/2010 8:10:06 AM",64.0625,FL
521,000002B500FC,"12/3/2010 8:10:06 AM",83.75,SU
521,0000027B8F2E,"12/3/2010 8:10:06 AM",103.8875,L4
521,0000027B71BE,"12/3/2010 8:10:06 AM",104.9,L3
521,000002B53FBE,"12/3/2010 8:10:06 AM",87.4625,RT
521,0000021DEB2D,"12/3/2010 8:10:06 AM",106.1375,L1
521,000002210993,"12/3/2010 8:10:06 AM",105.35,AIN
521,0000027B6CCB,"12/3/2010 8:10:06 AM",107.15,R1
521,0000027CE347,"12/3/2010 8:10:06 AM",56.525,IN
521,00000291CE67,"12/3/2010 8:10:06 AM",104.5625,R2
521,0000021DE117,"12/3/2010 8:10:06 AM",105.6875,R4
521,0000027CD87F,"12/3/2010 8:10:06 AM",-1.75,OU
